Diesel convert?
Old Apr 27, 2010 | 07:18 PM
mike-db's Avatar
mike-db
Diesel convert?
So I was talking the other day with a friend of mine, and the discussion came up about deisel vs gas, pro's and cons that type of thing.
We both decided that for what I'd use my truck for (daily driver, hauling loads, lots of long distance highway driving) that a diesel truck would be better suited for me.
Thing is I am very partial to my three on the tree 81 f150, I don't think I'll give it up unless it was totaled. So then we started talking about the possibility of a convert from gas to diesel, but a lot of questions an suspicions come up.
Like for instance, would a diesel engine even fit? Or if my transmission would work with a diesel engine, and if a whole lot of things wiring wise would have to be changed.
Discuss, for my amusement and education!
Old Apr 27, 2010 | 08:21 PM
bghnkinf250's Avatar
bghnkinf250
3 on the tree and diesel will not be suited for each other. The engine will fit, but is not ideal for the F-150 suspension. With having said that, they have been put into Broncos and such, so it CAN be done.
Old Apr 27, 2010 | 08:22 PM
mike-db's Avatar
mike-db
I'm thinking I'll just wait till my truck dies. Then go diesel.
Old Apr 28, 2010 | 12:43 AM
TheKirbyMan's Avatar
TheKirbyMan
You could consider a smaller diesel engine like a Detroit 4-53 or a Cummins 4BT. There are videos of both on YouTube. There's one truck on there with a 4-53 that will send chills up your spine. lol
I'm not sure how good the smaller engines would be for towing and hauling, but if you geared it right, I'm sure you could accomplish a fair amount.
Old Apr 28, 2010 | 02:05 AM
mike-db's Avatar
mike-db
No towing, I'm looking for the ability to still haul a load of firewood and hay every once in a while for a good hour drive (including the drive back it would be two hours).
And I'd like to have some good mileage, I'm not looking for more power probably the same amount. Just better fuel mileage (unless me switching to a detroit 4-53 lets say would not change it then I guess the conversation has been settled!)
Old Apr 28, 2010 | 09:57 AM
Franklin2's Avatar
Franklin2
If your truck has a 300 six in it right now, and you got a 4bt out of a bread van with a Ford chassis, the 4bt would bolt in. Cummins had a re-power program and made swap kits to pull out the 300 out of the bread vans and install their diesel in it's place. And I read somewhere the front frame of the bread van is the same as the 80-up pickups. The Ford vans came with a 4 speed, but the 3 speed should work also. 20mpg+ is obtainable with this setup.
Old Apr 28, 2010 | 11:55 AM
bashby's Avatar
bashby
So it would bolt up in a 302 or 351w truck also? Any custom $1,000,000 adapters needed or is it the same bolt pattern?
Old Apr 28, 2010 | 01:27 PM
mike-db's Avatar
mike-db
Hmmm well now I might want to start looking into if I actually have a 300 straight 6 or not. I've been told countless times that I do.
And I guess I have to look into the price range of a 4bt.
Old Apr 28, 2010 | 07:59 PM
Fordzilla80's Avatar
Fordzilla80
Today I was at school hangin out in the parkin lot,and I saw a silver 9th gen F150 Supercab Flareside 4x4 going through the pickup line.Well,I looked and thought what a nice truck.Then I heard it.It had a diesel in it.I did a triple take to make sure it wasn't an F250 with a flareside bed,but it had the 5 lug pattern on it,so it was indeed an F150.I wish I had my camera so I could make a video.So it CAN be done,and it makes for a pretty sweet truck.
Old Apr 28, 2010 | 08:38 PM
Franklin2's Avatar
Franklin2
Cummins already made the adapters and they are already on the engine if you get the one from a Ford chassis van. Yes it would bolt in a 302 or 351w pickup if you got the frame mount perches from a truck that originally had a 300 six. Remember they are different than the v8 perches.
eigenvector
1983 - 2012 Ranger & B-Series
21
Jul 19, 2006 07:12 AM
kaulike
Bio-diesel, Propane & Alternative Diesel Engine Fuels
42
Jun 12, 2006 01:21 PM
cookie88
74
Mar 23, 2006 10:18 PM
f100beatertruck
Jan 16, 2004 12:25 AM
