Caster numbers??
Old Nov 19, 2019 | 01:24 PM
Jk22's Avatar
Jk22
Caster numbers??
What caster numbers is everyone running after they level their trucks? I'm trying to eliminate my loose steering.
Old Nov 19, 2019 | 03:12 PM
adamsfbay's Avatar
adamsfbay
After the level (King coilovers and a trackbar relocation bracket) I was at 1.x each side, with a slight right drift at highways speeds.
After shims. I’m at 2.x on each side, and the truck is neutral, essentially zero bumpsteer, and a perfect feel.
Old Nov 19, 2019 | 03:53 PM
Jk22's Avatar
Jk22
I'm at 2.9 on each side now and the steering is loose. I've seen where some people are going as high as 4.0. Is this too much??
Old Nov 19, 2019 | 04:35 PM
saucemann's Avatar
saucemann
Mine was 4.1 drivers side and 4.3 passenger side from factory.
After 2.5" Readylift it was 1.9 drivers side and 2.2 passenger side.
Installed 2 degree shims and now 3.8 and 3.9, much more like factory feel.
Old Nov 19, 2019 | 04:58 PM
Jk22's Avatar
Jk22
Before you installed the shims, was the steering loose and floaty?
Old Nov 19, 2019 | 09:19 PM
Section179's Avatar
Section179
I haven’t leveled yet... but I did replace my radius arms and OBSESS about caster. Very happy with handling.
heres where I’m at post radius arms:
And here’s where I was factory (with regular springs - not plow)
LiquidSteam
May 31, 2018 09:25 PM
daniel044
Oct 16, 2017 03:01 PM
mgoolsby
Feb 24, 2017 08:35 AM
theenforcer
Aug 6, 2012 06:59 PM
chambers1517
Apr 20, 2010 10:14 AM
