Need help finding hardware,Paging NumberDummy!
Let me say first that I've tried to do my due diligence and find this hardware myself using the parts manual, I just keep getting lost in it trying to find what I need.
I need 2 of the lower bolts that hold the wheel spindle on. One of them I had to drill out because it was seized and the other seems to have grown legs and run away on me. I would actually replace all of the spindle hardware if it was available.
I'm also looking for the bolts that holds PN C4TZ-7507-A to the frame. That is the frame side of the clutch Z Bar. One of these snapped in the frame as I was taking it off, luckily lots of heat and PB Blaster let me get the broken piece out.
Thanks in advance to anyone that can help me out.
Ted
Ted
I'm also looking for the bolts that hold C4TZ-7507-A outer pivot to the frame.
2) 370110-S8 .. Lower Spindle Bolt - National Fine Thread ~ 1/2" -20 x 2 51/64" long - end drilled / Obsolete
KLIMESH MOTOR SALES in Calmar IA has 10 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 14 = 800-476-9653.
2) 370113-S8 .. Upper Spindle Bolt - National Fine Thread ~ 1/2" -20 x 1 11/16" long / Obsolete
KLIMESH MOTOR SALES has 11.
2) 20388-S8 .. Bolt-Outer Pivot to Frame ~ 3/8" -16 x 1.00" long / Obsolete
No Ford dealer or obsolete parts vendor has any NOS, none on ebay.
