Side molding Removal
Old Nov 17, 2019 | 02:09 PM
Mitchapalooza85's Avatar
Mitchapalooza85
So next month I'll be sanding down the worn base coat from the truck including some minor rust, has anybody removed the lower side molding/trim before. Not finding much luck on all the locations behind the body panels to remove these. Most of them I can't even see the on the underside.
Old Nov 17, 2019 | 03:29 PM
Franklin2's Avatar
Franklin2
You will find a combination of nuts, screws, and plastic clips riveted to the body. Here's a picture.
https://www.lmctruck.com/1980-96-for...y-side-molding
thumper7741
Dec 5, 2012 03:39 PM
Caruso72
Aug 14, 2012 03:05 PM
jlt13th
May 3, 2012 12:53 AM
flysniper
Apr 8, 2009 09:36 AM
ramtoo
Nov 29, 2005 02:49 PM
