Trim Removable?
Old May 1, 2012 | 04:22 PM
jlt13th's Avatar
jlt13th
Trim Removable?
Hi.Is it possible to remove the trim from a 1970 f100?Id like to remove it from my doors,because theres a gap on the top and its getting rusty behind the trim.Thanks!
Old May 1, 2012 | 06:21 PM
HIO Silver's Avatar
HIO Silver
You mean remove the trim from the drip rail? Or remove the trim from the bump bodyline? In both cases, yes. However, reinstalling them can be a real pain not to mention the likelihood of breaking a clip. The roof rail can be removed with a bottle opener...very gently.
Good luck to ya.
Old May 1, 2012 | 07:39 PM
tmcalavy's Avatar
tmcalavy
Yep, best way to remove body trim is with a paint scraper or putty blade. Press in on the trim...push it against the body and slide the scraper/blade along the body (carefully) behind the trim. When you feel a clip with the scraper, apply more pressure there and some downward force, then pry out with the scraper (gently). This should pull the bottom lip of the trip off the clip, then you can lift it off from the clips from the top.
Old May 1, 2012 | 08:09 PM
jlt13th's Avatar
jlt13th
Hey guys.Yeah im talking about the body bump trim..So will this method you laid out tmcalavy work for the body that?Thanks again
Old May 1, 2012 | 08:52 PM
MIKES 68 F100's Avatar
MIKES 68 F100
tmcalavy you forgot
plastic clip breaks in half and falls to ground .. lol
at least 50% of my clips broke apart even with being careful .
clips are like $2.00 each at LMC ,NPD or DC
Old May 1, 2012 | 08:53 PM
MIKES 68 F100
oh and at the ends of each trim piece there's nuts that hold them on take those off first
Old May 1, 2012 | 10:54 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by MIKES 68 F100
tmcalavy you forgot
I have envied yall with the bump moulding in the past. However the more I think of it, I have grown to like my stripper F100 Custom for the reasons stated above.
Old May 1, 2012 | 11:59 PM
jlt13th's Avatar
jlt13th
I like the body bump style on the ones that are simply part of the truck itself.But I dont like the way mine is,where the body bump is a separate piece.Anyone know why Ford made some with the trim body bump and some with the bump molded right into the sheet metal?
Old May 2, 2012 | 07:37 AM
tmcalavy's Avatar
tmcalavy
yep, keeping clips intact is optional. cleeps?? we don need no steenking cleeps!!
yeah the method I described works for the body/bump trim...if its loose enough you may not need a scraper/blade.
Old May 2, 2012 | 10:41 AM
BlueovalFE's Avatar
BlueovalFE
I bought all new bump trim for mine. Should be finished with the paint in another week or so and I'll finally get to see what I spent so much money on
Old May 3, 2012 | 12:53 AM
jlt13th's Avatar
jlt13th
Got a link to your truck blueovalIFE?
thumper7741
Dec 5, 2012 03:39 PM
4x484150
Jun 2, 2012 08:17 AM
JRon
Aug 19, 2010 08:07 PM
flysniper
Apr 8, 2009 09:36 AM
cajunbuck
Paint & Bodywork
Apr 20, 2002 01:18 AM
