2003 F350 hub replacement
Old Nov 16, 2019 | 11:50 AM
Lockholder's Avatar
Lockholder
I had a Clunking noise coming from my driverside front wheel well, so I replaced the hub assembly to find out it was the other side instead. So I replaced that hub as well there’s no clunking and no ABS light. Sway bar disconnects I gotta check still, but ujoints didn’t have play. Driverside axle shaft was fine passenger seat had to move the shaft to get the hub back on. Now when I drive I hear a light skimming noise as if a caliper is slightly touching the rotor type noise.
Old Nov 16, 2019 | 03:47 PM
kbeefy's Avatar
kbeefy
Check your brake backing plates, they can get bent inadvertantly and rub the rotor while driving.
Old Nov 20, 2019 | 06:01 AM
Lockholder's Avatar
Lockholder
Sorry for late replying. So if you’re referring to the dust shield or whatever you wanna call it, it was flush to the rotor so I bent it outward and the noise went away, but now I notice at 73+ there’s this humming noise. Like I’ll drive it’ll start quite hum a bit then go away and then come back and so on. But if under 70 it doesn’t make it
Old Nov 20, 2019 | 05:09 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Get a inflared temperature gauge, less than $15, and check rotor temps.... that will tell you if pads are rubbing on rotor.
Did you replace seals on the hubs ? I'm guessing its like my 2001?
Old Nov 20, 2019 | 05:39 PM
Walleye Hunter's Avatar
Walleye Hunter
If that backing plate is bent just right it could be catching air at those speeds and humming. Compare it to the other one and try to make them similar.
Old Nov 20, 2019 | 08:42 PM
kbeefy's Avatar
kbeefy
I'd suspect tire balance or ujoints at 70+ mph, just a guess though
Old Nov 20, 2019 | 09:18 PM
DieselDenny's Avatar
DieselDenny
Talking
Check lug nut torque as well
Old Nov 25, 2019 | 08:19 AM
Lockholder's Avatar
Lockholder
So the noise is rarely now. Back plate is good I checked the ujoints. But now when I turn around corners and what not I hear a clunking like something is binding...
Old Nov 25, 2019 | 08:56 AM
Lockholder's Avatar
Lockholder
So I crawled under it. Sway bar is tight hubs are still tight driverside ujoint I turn and it’s sturdy but turns freely. I checked the passenger side the ujoint itself is tight but the axle has play in it, I can wiggle it with my hand it wobbles. I saw there’s suppose to be play in it but I dunno if it’s excessive play or not
Old Nov 26, 2019 | 10:56 AM
Lockholder's Avatar
Lockholder
so I checked springs and shocks and anything front end wise and everything seems to check out to be correct. The passenger side shaft still has play on it. The outer seal is broken, it has been for a bit cause I seen it leaking months ago. Still chasing down the clunking noise when turning. The humming noise stops when I turn on the highway doing 70+ but once I straighten out it hums again
Old Nov 29, 2019 | 10:34 AM
steelandspeed's Avatar
steelandspeed
@Lockholder Have a look at my post about clunking noise please... it might help.
https://www.ford-trucks.com/forums/1...ight-size.html
Old Nov 29, 2019 | 10:56 AM
Lockholder's Avatar
Lockholder
yeah I seen your post and I was following it. I checked u joints, hubs are new, front shocks and springs are new, I’m about to check ball joints here soon to see if they are bad
Old Nov 29, 2019 | 11:50 AM
AllaboutMPG's Avatar
AllaboutMPG
I know you said sway bar is tight but I had a similar issue and it was one of the drop links for the sway bar.
I had them off to press in new Energy Suspension bushings along with a bunch of other front end work. Shortly afterward I developed a clunk , especially when turning and going over a bump. Even though all the parts I worked on "felt" tight I put a wrench on every bolt I could get too. The driver side sway link upper bolt was snug , probably loaded a little by the sway bar, but was not tight. After torquing it no more clunk.
Martin Torres
Mar 3, 2019 06:11 PM
BigNick98
17
Dec 20, 2014 06:29 PM
superglide04
Mar 18, 2014 09:02 PM
Jpritchard
Sep 21, 2004 10:12 PM
