Auto-temp
Old Nov 14, 2019 | 07:07 AM
1956mike's Avatar
1956mike
Auto-temp
Noticed on the auto temperature control for climate that when we select to have more airflow to an area using the appropriate switch it turns the auto temp off. Looking in manual I couldn’t determine if that’s the intended way or it’s an error.
Old Nov 14, 2019 | 07:12 AM
seville009's Avatar
seville009
Think it’s normal because if you redirect the airflow, my guess is the temperature sensors in the various locations would get “confused”
Old Nov 14, 2019 | 07:58 AM
BocaIvan's Avatar
BocaIvan
From my understanding, if you select anything other than the temp while on Auto, it will disable the Auto function.
That said, I never use Auto.
Old Nov 14, 2019 | 09:00 AM
HRTKD's Avatar
HRTKD
This is my experience. I use Auto most of the time and have few issues with it. If it's too warm in the cab but I want more air, I roll down a window or open the sunroof to cool it down.
Old Nov 14, 2019 | 11:30 AM
1956mike's Avatar
1956mike
So auto is not so auto ... lol. Thanks
Old Nov 14, 2019 | 12:02 PM
BocaIvan's Avatar
BocaIvan
Auto is auto as long as you set the temp and forget about it. Lol
Here in South FL, I set mine to 60 and to blow only through the front vents. I adjust the fan speed depending how hot the truck gets.
The heater may get turned on a few times in the year...
Old Nov 14, 2019 | 03:54 PM
rfbrain's Avatar
rfbrain
it's Auto until you Manually change it..............
Old Nov 14, 2019 | 05:15 PM
C12H24's Avatar
C12H24
It's actually a very sophisticated system. If you leave it in auto, it will put air where it's needed based upon outside temp and the temp you select. When it's cold, it will automatically direct air to defrost or defog, to the floor, to the side windows, and a little out the dash vents depending. I always leave mine in auto or in OFF with the window down.
Old Nov 15, 2019 | 03:42 PM
D3thM3tal's Avatar
D3thM3tal
I leave my truck in auto and love it. Windows never fog up and I'm always comfortable in conjunction with the heated seat and steering wheel. The only time I mess with it if my feet are hot or cold from the conditions before I get in the truck, it does impressively well.
Wyldfire
Oct 2, 2019 02:55 PM
chiefgeek69
Jul 25, 2018 10:21 AM
Fort Ruker
Jul 27, 2005 11:46 AM
