One Headlight
Old Nov 13, 2019 | 12:44 PM
applebaggins's Avatar
applebaggins
One Headlight
Hey, folks - my 1978 F250 headlights were working just fine on regular brightness, but when I hit the high-beam switch on the floor, the passenger side bulb got stuck on high. Any ideas how to fix this?
Thanks!
Old Nov 13, 2019 | 01:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
To trouble shoot it I would swap the bulb positions and see if the issues moves positions. If it does, I bet floor dimmer switch is bad?
To just take that step out of the equation, just replace the floor dimmer switch.
Old Nov 13, 2019 | 03:47 PM
dlburch's Avatar
dlburch
does the drivers side high beam filament and the hi-beam indicator on the dash switch on/off normally?
Old Nov 14, 2019 | 08:12 AM
applebaggins
The dimmer is on the floor, but it doesn't make a difference. I can turn the lights on and off completely by the dash switch, but activating the dimmer doesn't change the status of either filament.
Old Nov 14, 2019 | 09:53 AM
fordguy2100's Avatar
fordguy2100
He's asking if the "brights" indicator light on the dash panel comes on and off when you hit the switch on the floor.
Least that's how I read his question.
Old Nov 14, 2019 | 10:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the dimmer switch is defective, when you step on it to switch from low beams to high beams (or vice versa), the headlamps will go out.
This is a very common occurrence with this switch (C0TZ-13A024-A / Motorcraft SW-263) that was used on most 1960's/90's FoMoCo vehicles.
Old Nov 14, 2019 | 11:08 AM
1TonBasecamp's Avatar
1TonBasecamp
These two statements when taken together don't make sense. So which is it? Does the passenger side stick on high, or does flipping the dimmer switch not change the status of either bulb?
For now I'll go by the first one and ask if the driver's side goes to high beam too, or does it go out? If it does go to high, does it go back to dim when you hit the dimmer switch again?
Does turning the headlight switch off reset them to work the same, or does the passenger side stay on high now, no matter what you do?
If so, that does not sound like the floor switch since it should effect both lamps. I guess I better go out and look at mine again, but if there is only one wire out to the low beams and one wire out to the high beams, it can't be the switch effecting only one lamp.
As was asked, does the driver's side high beam come on at all? And does the dash indicator light come on?
I realize you responded to the question, but that answer was very confusing.
If the answer to those is no the driver side does not activate on high and the dash light does not come on, then it's very possible your switch has gone AWOL like the others have already said.
Paul
Old Nov 14, 2019 | 01:31 PM
NumberDummy
I'm whizin' along on I-40 late at night in my '65 F100 between Barstow and Needles. I was headed to Seligman AZ to join a Route 66 rod run.
With little traffic coming the other way at 2AM, I'd flick the switch to high so I wouldn't run over a rabbit, tortoise or hit a jackass (the 4 legged variety), all of which were common out there.
One time when I flicked on the switch to high, the *** **** headlamps went out. I knew what the problem was...corroded switch.
So I pulled over, stopped, reached under the seat, grabbed a crescent wrench and hit the switch several times. The lights came back on...and I never had the problem again.
Old Nov 14, 2019 | 04:01 PM
applebaggins
My apologies. When I pull the switch on the dash, the headlights turn on. The driver side is normal, but the passenger side headlight is stuck on high-beam. I hit the switch on the floor and there is no change. I push the switch on the dash and the lights turn out. Basically, the lights are perpetually stuck with driver side on regular brightness and passenger side stuck on high-beam.
I don't recall seeing an indicator light on the dash at all.
Ouch!! Glad you're ok! That's a pants-changing moment for me.
Old Nov 14, 2019 | 05:46 PM
Tedster9's Avatar
Tedster9
Ah, good ole "percussive maintenance", eh?
Old Nov 14, 2019 | 05:56 PM
NumberDummy
It's there, all trucks have one
Pic: Notice the location for the hi beam indicator light, the bulb has probably burned out, it's a #194 bulb and it just pushes into the socket.
Same bulb used with the gauges, front fender and rear marker lamps.
But be careful, because the original 1975/79 F100/350, 1975/80 Econoline, 1978/79 Bronco instrument cluster backs were made of a composition material that can TURN TO DUST before your very eyes!
Instrument cluster back shown as 10848 in pic. With oil/amp gauges is different than with oil/amp warnings lamps, the 10K843 printed circuit boards are also different.
Old Nov 15, 2019 | 05:15 AM
rob8210's Avatar
rob8210
I may be a dumb old fart , but I would just change the offending headlight. Probably just an internal problem with the lamp itself.
Old Nov 15, 2019 | 01:55 PM
1TonBasecamp
Yeah, except now we know they're both offending. So I would start with the floor switch myself, but instead of just replacing it (which is what I used to do and probably what's needed anyway) I would jumper two wires together. First the low beams, then the high beams to see what, if anything changes.
Then I would test the headlamps themselves individually. See if power is getting there, and where it's getting and why.
With the driver's side stuck on low beam, and the passenger side stuck on high beam, and the dash indicator lamp not working, you probably have multiple issues.
Hence the need for some testing. If you follow the wires and find some breaks and splices and household wire nuts, and lots of fresh electrical tape, I'd start digging into the harness.
But some simple testing with a volt-meter will tell you what needs what.
As said, the High-Beam Indicator could be burned out. But if the floor switch is not working and switching to high position, the indicator lamp will never come on even if it's good.
Since getting into the dash is more of a pain than testing the floor switch and lamps and wires under the hood, that's where I'd start.
Paul
Old Nov 15, 2019 | 06:21 PM
John89's Avatar
John89
I am with Bill, rap the dimmer switch with a wrench, hammer, screwdriver etc... and see if it helps.
As my granddad used to say "if this doesn't fix it, try a bigger hammer"
Old Nov 15, 2019 | 07:39 PM
Tedster9's Avatar
Tedster9
"BFH" is the technical nomenclature.
