Aerostar Ford Aerostar
Parking Brake Cable
Old Nov 12, 2019 | 12:30 AM
mediaman67's Avatar
mediaman67
Parking Brake Cable
Ok, so I have an 89 shorty that has the hand pull parking brake lever
it was so tight that it wouldn't release when I did my rear brakes so I could hardly get them back on.
I ended up cutting the cables just so the wheels would free up
I have 2 new cables - same for left and right right?
my question is, does anyone know if I can just join the three together in such a way that I can make the adjustment at the end of the single cable that feeds that other 2? instead of messing with that handle, etc?
anyone do this?
Thanks
Old Jan 14, 2020 | 09:06 PM
Mikeman's Avatar
Mikeman
Is your parking brake handle between the front seats or is it T-shaped? I replaced the parking brake cable (the front one) on my extended '97 at least twice before it was totaled. The aftermarket cables don't last that long and I think I'm one of the few people in this world who use the parking brake every time I park.
Replacing the forward cable was a PITA, but you have to make sure you completely unwind the parking brake lever/spring assembly. If I remember correctly, I had to use some vise grips to keep it from rewinding while installing the cable. And you have to get creative with straps and cable ties or flare nut wrenches to remove the cable housing (there are tabs that need to be compressed) where it goes through a structural member.
Old Jan 15, 2020 | 09:56 AM
mediaman67's Avatar
mediaman67
Hi Mike,
I have the handle that is next to the drivers side seat. - the front cable is still fine, but what I wanted to do, was tie the two rear cables to the front one, but have a way to adjust it there at that junction, so if I ever do the rear brakes again, I can release the tension there, since the handle seems to be a mystery on how to adjust it, etc.
I know that everything corrodes over time under the truck, but there must be a good "one and done" idea, where I have access to it, but I won't have to cut the cables again next time.
Old Jan 15, 2020 | 07:55 PM
Mikeman's Avatar
Mikeman
From what I remember, there really is no way to adjust the cable other than through the drum brake adjuster. You have to adjust the brake shoes inward (smaller diameter) frequently, in order to remove the drum because the drum usually develops a lip on it that prevents the drum from being removed easily.
My Toyota parking brake cable has a stud with a nut on the end to adjust the cable. It has rear disks. It would be nice if Fords had this feature.
grip
Aug 25, 2012 08:00 PM
ccarrier
Dec 29, 2010 10:53 AM
ptaylor-01
Apr 22, 2010 04:04 PM
little truck
1983 - 2012 Ranger & B-Series
Sep 9, 2007 07:07 PM
RyanMiller
Oct 10, 2004 10:34 AM
