ICP Sensor Replacement Repair Tip
Old Nov 11, 2019 | 05:24 PM
Gotanoldtruck's Avatar
Gotanoldtruck
1997 with 330,000 miles has been surging slightly for about a year driving me nuts. At first I thought it was the torque convertor slipping, but it turned out to be the sensor. The original OEM sensor has a 5/8" nut on the underside of the sensor. I tried a clawfoot wrench but it was too thick to fit under the sensor and in the "well" of the head. The only way I could get it out was to create my own 90 degree wrench from an old cheap box wrench. (See picture below). I ground it down a bit, heated it with a MAP torch in a vice, and hit/tapped it with a 5lb hammer until it was a 90 degree angle. "New tool" worked like a charm with a long extension through the closed end of the wrench. Based on advice on this forum I bought the Motorcraft part, F6TZ9F838A, which replaces the 5/8" underside nut with a 1 1/16" nut on top of the sensor. Truck is running like new, and not bad for 22 years old.
Old Nov 11, 2019 | 07:41 PM
97-psd's Avatar
97-psd
Innovative tool. I usually use a large pair of vise grips on it. It will definitely damage the sensor, but I plan to replace it so damage is not a concern
jim48
6.7L Power Stroke Diesel
May 31, 2014 11:09 PM
Cell's
Mar 18, 2014 11:24 AM
Milky1112
13
Jun 23, 2013 05:59 PM
dothedew192
Oct 22, 2011 09:50 PM
Kansas-Mike
13
Apr 6, 2005 07:08 PM
