I have oil in my ICP connector and sensor so I guess I have to replace the sensor .
The new ICP sensor has a larger nut on it where mine has the nut that is under the body of the sensor . I am wondering if that is the only difference between them or if the new sensor is updated by ford ??
I found that to be the case as well. I think they just made it that way because it is much easier to get a wrench on than the old design. It's just a pressure transducer so I doubt there is much to update about it.
