replacing icp sensor. 02 engine.
Old Oct 22, 2011 | 04:52 PM
dothedew192's Avatar
dothedew192
Hey guys, I'm in the middle of replacing my icp sensor and when I went to remove it, the bugger is round? There is a nut underneath it, but I'm not sure if that's just a mount it screws into? Where the threaded end of the sensor would be, is where this nut is located. My new sensor has edges where I can tighten it or loosen it where as this old one is round. Any advice? Try to remove it by wrenching on the nut part?
Old Oct 22, 2011 | 05:15 PM
cj45lc's Avatar
cj45lc
you need a crow's foot to get the old one out, I believe it was a 5/8"
shoot if it's bad I guess you might could get it with vice-grips on the round part
Old Oct 22, 2011 | 05:18 PM
PaysonPSD's Avatar
PaysonPSD
The old style is removed with a 5/8" open end on the hex portion.
The new one can be installed with a deep 1 1/16" socket.
Edir: Lubricate the the new o-ring. Motor oil works fine.
Old Oct 22, 2011 | 07:02 PM
dothedew192
Thank you everybody. I got screwed in the middle of this operation by having no 5/8s crow wrench so I got a tiny pair of vise grips on the nut and pried against it and within a 1/4 turn it was loose. Beautiful thing that innovation
Old Oct 22, 2011 | 09:00 PM
cj45lc's Avatar
cj45lc
My Daddy always said "where there is a will, there is a way"
glad you got it
Old Oct 22, 2011 | 09:50 PM
dothedew192
That's right! Put fifty miles on already and noticed better, quicker starts, and better smoother acceleration thru the power range.
jim48
6.7L Power Stroke Diesel
May 31, 2014 11:09 PM
Cell's
Mar 18, 2014 11:24 AM
Milky1112
13
Jun 23, 2013 05:59 PM
Supercab
Oct 10, 2009 06:55 PM
Ford79
Aug 26, 2007 01:44 PM
