Battery light flickering
Old Nov 13, 2019 | 07:40 AM
RA101725's Avatar
RA101725
Banned
Originally Posted by Walleye Hunter
Putting that in the dash is one of my favorite mods. It has already saved me from going down over a bad alternator and it's like having a glow plug LED indicator.
It gleans some interesting insight into what the truck is doing with a real time voltage reading (glow plugs, AIH, etc)
Old Nov 13, 2019 | 07:48 AM
RA101725's Avatar
RA101725
Banned
There is a guy “Toomanytoys” who posts in the 6.0 forum who made some neat YouTube videos showing how you can get some better idle output from the 110 or 140 amp alternators by putting a $15 overdrive pulley on it. I put one on my stock 110 amp figuring “eh what the hell”. He has used the 110, 140 and 230 amp Leece-Neville unit and has run tons of tests on how they all perform.
I dont think you have to worry about the wiring by swapping the 6.0 Bosch unit on there. It’s a very mild upgrade. But that is what I would do is slap a new alt on there and see what happens regarding the original problem. It is probably just a shot voltage regulator.
Old Nov 13, 2019 | 08:29 AM
ajbrown208's Avatar
ajbrown208
When you find the one you want, slap some paint on the bad boy. When I get done, under the hood will look like a spilled bag of Skittles.
Old Nov 13, 2019 | 08:36 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by ajbrown208
When you find the one you want, slap some paint on the bad boy. When I get done, under the hood will look like a spilled bad of Skittles.
I had to ask my wife the color of that alternator, she said "sea foam" and she likes it!
Old Nov 13, 2019 | 08:50 AM
ajbrown208's Avatar
ajbrown208
Truck will be my daughters one day. So she is getting to pick the colors.
She is Daddy helper too. Very mechanically inclined.
Old Nov 13, 2019 | 09:35 AM
brian42's Avatar
brian42
Veteran: Navy
I kept the OEM wiring and it was plug and play for the units I bought.
I wish I could personalize my component colors. With CA being very strict on visual inspections I specifically avoided that as the less stock it looks under the hood the harder the inspector looks to verify OEM components.
Old Nov 13, 2019 | 09:41 AM
Tedster9's Avatar
Tedster9
I always called that "Insane Asylum"; because it was apparently one of the least expensive paint colors available so muncipal governments used to use a lot of it in paint schemes in buildings, water towers, fire hydrants &c. At one time governments were almost frugal (at times) about spending other people's money. Sounds crazy today, but it's true.
Old Nov 13, 2019 | 03:08 PM
woodnthings's Avatar
woodnthings
Have you checked belt tension? Flickering under load can be caused by the belt being too loose. The alternator seems to check out per your post.
Old Nov 13, 2019 | 08:29 PM
beef tits's Avatar
beef tits
Bosch 6.0 alternator installed... problem seems to be solved!
Thanks for all the input.
Old Nov 14, 2019 | 12:30 AM
RA101725's Avatar
RA101725
Banned
that place is worse than Hitler and Stalin combined.
Old Nov 14, 2019 | 07:04 AM
Djosbun's Avatar
Djosbun
I don't normally post in this part of town, but seeing the above post put a big smile on my face.
Great kids come from great parents. Well done, my friend. Well done.
-- Dave
Calheader
Nov 19, 2014 02:30 PM
adammdennis11
Nov 25, 2013 07:07 AM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
john1
Aug 22, 2006 12:46 PM
coloradotoy
Mar 3, 2004 11:07 PM
