Hard Start
Old Nov 11, 2019 | 01:47 PM
Shelstin's Avatar
Shelstin
Hard Start
2003 6.0. 95K miles.
I recently replaced a battery hoping that would alleviate the problem. The other battery was replaced in May. I place a charger on it at night to insure that they are both charged, because I read that it may be a voltage issue. It has only been a problem since it got colder, although it is always garaged.
I won't try to start it for about 10-15 seconds after the "glow plug light" goes out. Sometimes I will recycle, to see if it makes a difference. It will usually start, but not until the third or fourth try of about 10 seconds or so. I have a feeling that it may be a fuel pressure issue. I am anything but a mechanic, but that is what my gut is telling me. After starting, it almost always starts right up unless it sits for an hour or so.
I will take it to a mechanic, but I would also like to have an idea of your thoughts.
Thanks in advance.
Old Nov 11, 2019 | 01:57 PM
AL`'s Avatar
AL`
How's your FICM voltage? Should be 48 volts. Hopefully, you have a scanner that can read the codes from the OBD port. Low batteries can kill your FICM if not caught soon enough. Bad FICMs can kill injectors. Not saying that's the problem, but you had battery troubles and starting systems struggle in cold weather.
Old Nov 11, 2019 | 02:44 PM
AL`'s Avatar
AL`
I had similar symptoms years ago. Here's a data log screen capture of my FICM voltage using AutoEnginuity. Scale for Battery voltage on the left, FICM on the right (dark blue trace). The FICM voltage falters below 48, down to about 43.2, then recovers. I post to show that sticking a voltmeter on the FICM for a few moments might give a false indication if not checked over a long enough period. A monitor of some kind sure makes life simpler.
bismic's Avatar
bismic
Cycling the key for glow plugs really isn't needed. They stay on for quite awhile after the light goes out.
Watch the voltage w/ the key on (before cranking) and you can see when the glow plugs go off (the voltage comes up at that point).
Having a scan tool to watch FICM voltages (MPower, LPower, and VPower) is highly advised.
Old Nov 11, 2019 | 05:19 PM
Shelstin's Avatar
Shelstin
I don't have a scanner.I need to get it to someone who does.Thanks for your advice.
Old Nov 12, 2019 | 02:33 PM
6point0's Avatar
6point0
There are a bunch of us that have the torque app along with the obd module.
Is there a post on here that tells how to get all the gauges that is needed?
....for his information and mine to be honest. I have voltage and coolant and a few other one. I've never been very techy.
Old Nov 12, 2019 | 03:15 PM
bismic's Avatar
bismic
Old Nov 12, 2019 | 05:37 PM
TooManyToys.'s Avatar
TooManyToys.
You can't diagnose anything with this truck without data. An adapter and cell phone software is cheaper than any generic scanner and won't give you false or incomplete data.
Old Nov 12, 2019 | 07:01 PM
AL`'s Avatar
AL`
Yeah, a generic OBDII reader isn't much help. I'm not up on the latest and greatest. My in-truck monitor is a little dated and not even offered anymore, although I think the nDash is its progeny. Mine is a DashDAQ-XL with Ford package. I see lots of mentions of the Torque app and FORscan. Are those the two most go with now if they don't have a tuner? Is there a consensus which is better?
The DashDAQ wasn't cheap, so I'm kind of invested but it's still pretty useful. I could make it more so since it has two auxiliary analog sensor input channels. Priorities to add would be fuel pressure and coolant pressure. Wouldn't mind having oil pressure too.
Old Nov 12, 2019 | 07:12 PM
bismic's Avatar
bismic
The DashDAQ is nice, but it doesn't do FICM MPower and it isn't nearly as thorough a code reader as ForScan Lite.
Old Nov 12, 2019 | 08:25 PM
Mich6.0's Avatar
Mich6.0
will bad glow plugs throw a check engine light
Old Nov 12, 2019 | 08:50 PM
tfunk88's Avatar
tfunk88
I have a DASHDAQ XL, it does both FICM Main Power and Logic Power.
I wasn’t aware it wasn’t a good code reader, perhaps it’s time to get one of the ForScan versions.
Old Nov 12, 2019 | 08:54 PM
bismic's Avatar
bismic
Mine will absolutely not properly read the 48 volt FICM power (only shows a max of 12 volts). What is your PID labeled? It has been a long time since I looked on their forum, but they didn't have a way identified then - say maybe 2012 time frame.
Old Nov 12, 2019 | 09:00 PM
tfunk88's Avatar
tfunk88
I’ll check tomorrow morning when I get back in the truck
I got the full Ford PID’s around 2015-2016, so maybe it was updated...but I think I remember them saying FICM Main Power was named something that wouldn’t make you think it was FICM Main Power, and I had to rename it.
Old Nov 12, 2019 | 09:14 PM
bismic's Avatar
bismic
TY .
