#!@$#@$#@$@#!@ REGENS
Old Nov 11, 2019 | 11:31 AM
AlphaInfinity's Avatar
AlphaInfinity
To summarize, the truck is going through a regen roughly every 120 miles. It doesn't matter if the trips are long, short, towing or not towing. The worst part is that it takes 30 miles of highway driving to clear the filter down to 0. Just wondering if anybody else has been having this problem. Took it into the dealer and they didn't have any advice.
Old Nov 11, 2019 | 11:33 AM
MC_Greenmachine's Avatar
MC_Greenmachine
Well if you're looking for advice, delete it before all the good tuners are gone into the shadows because of the damn EPA
Old Nov 11, 2019 | 12:23 PM
ForCal's Avatar
ForCal
How many miles on the truck? From 0% to regen in only 120mi. seems like something is off. Mine is pretty new still, only 3k mi., it seems to regen at or around the standard 500mi. range. Since having the dpf% screen enabled I've seen it go to 0% once, a couple other times only to 30% because my drive time wasn't long enough. It does take a decent amount of drive time to get it down.
Old Nov 11, 2019 | 12:24 PM
tortue71's Avatar
tortue71
Nox sensor on mine was the culprit. No lights of any sort also
Old Nov 11, 2019 | 12:27 PM
Flitastic's Avatar
Flitastic
Originally Posted by ForCal
How many miles.on the truck? From 0% to regen in only 120mi. seems like something id off. Mine is pretty new still, only 3k mi., it seems to regen at or around the standard 500mi. range. Since having the dpf% screen enabled I've seen it go to 0% once, a couple other times only to 30% because my drive time wasn't long enough. It does take a decent amount of drive time to get it down.
my truck is new as well. Only 2600 miles. It does a regen every 350-400 miles depending and it’s NEVER gone down to zero percent. 23 is the lowest it has ever gone. Normally it’s in the 30s
Old Nov 11, 2019 | 12:45 PM
AlphaInfinity
From 0 to 100 percent full it is roughly 120 miles. The truck has 20,000 miles on it.
Old Nov 11, 2019 | 02:19 PM
tortue71's Avatar
tortue71
That's what mine did until the nox sensor would just quit and the truck was showing 0% if it where not for forscan , I would never know and probably went into limp mode while on my way to Florida with my fiver.
I had no light on , called my dealer and explained what was happening to them. They ordered a new nox sensor and stopped at the dealer with my trailer. I unhooked , they got it in the shop , changed the sensor and on my way I was. Trouble free since
Old Nov 11, 2019 | 02:44 PM
Projectlittleredf250's Avatar
How do you enable the DPF % screen? Only thing i have to the DEF level. I'm guessing its through forscan?
Old Nov 11, 2019 | 03:49 PM
ForCal's Avatar
ForCal
Forscan, or the dealer can enable it.
Old Nov 11, 2019 | 04:07 PM
Thanks ! Ill have to check for scan tomorrow
Old Nov 11, 2019 | 04:40 PM
Lamoon78's Avatar
Lamoon78
9,000 miles and no regen yet and some may think it’s bull crap but run Archoil in it the stuff does what it claims.
Old Nov 11, 2019 | 04:54 PM
Norris McCarty's Avatar
Norris McCarty
I've got 16K miles on my 2018 and never seen, heard or felt a regen. Why would you want to know when it's happening?
Old Nov 11, 2019 | 05:01 PM
cpobst's Avatar
cpobst
From what I understand the truck will regen every 500 miles whether it needs to or not. How are you coming to the conclusion that it has not done a regen?
Old Nov 11, 2019 | 05:27 PM
Lamoon78's Avatar
Lamoon78
Nothing is telling me it’s doing. How are you guys knowing that it’s doing a regen.
Old Nov 11, 2019 | 05:29 PM
cpobst's Avatar
cpobst
Nothing tells you and it is about impossible to detect it. I can tell by watching my DPF % drop which I enabled using Forscan. If I shut it off during a regen I can smell it but other than that is is undetectable, at least to me.
