#!@$#@$#@$@#!@ REGENS
My question is will I see the same white cloud during regen in my new 2020 6.7? Thank you
New here, long time ford owner. I currently own a 2008 f250 6.4. Regens are horrible in my current truck, white smoke/steam envelopes everyone behind me on cold temp mornings. People who don’t know accuse me of “rolling white coal”.
DEF is not part of the regen process. DEF is used as part of the SCR to reduce NOx gasses which become higher as EGT's go up. This would explain why you are using more DEF while towing. Passive regen is a result of the EGT's being high enough to burn off the soot in the DPF. Again, this occurs while towing. On our first camping trip in my 2017, the DPF% screen never changed during the 130 mile highway trip. It was only after we started driving slower through back roads where it began to go up again.
It's important to have a way to monitor EGTs because of the above comments. It's also important to let the truck idle after driving hard or towing / hauling heavy. I usually line to wait until EGT11 & EGT12 are in the low to mid 300 F range before shutting off the truck but maybe I'm being a little cautious.
I agree, I also think that the horror stories from the 6.4 have tainted any new technology going forward. For me I have several close friends with close to 300,000 miles on their 6.7's and the OEM emissions equipment is still intact with no issues from it. One truck is a BNSF F350 crane truck with lots of idle hours. The other 3 are Foreman trucks with a local construction company. They all have around 11,000 engine hours with over 5000 idle hours on them. One has had a turbo replaced and egr valve replaced but the others have been solid. These are the early models, 2011-2014. I know most of us take better care of our trucks than these guys so I think it is a testament to the new technology. I know, there is always an exception but I think on the whole its best to just drive them and not think about it.
1200 miles on My 19' F-450- down to 3/4 tank on my DEF. Admittedly, the truck sits a lot but not idling- just parked. My Banks Derringer tells me when I'm Regen mode and its a lot. (like the OP). Ill try that Archoil and see if that works. At this point its a wash between buying boxed cat **** or an additive
My 2019 has 2900 miles and according to the DPF% screen, my distance between regen is around 150 miles + or - 15 miles. However, I do mainly city stop and go traffic driving. The 30 miles highway driving to clean the DPF down to 0% seems about right as I observe my takes around 25 miles interstate driving. I have read about people getting the dealer to reflash their truck ( not sure if it's ECM, PCM, or whatever.) so perhaps ask about that. It should also be mentioned that at least one of those person said post reflash their truck saw a DECREASE in MPG, but if you're unhappy with your current situation if might still be worth a shot. Other than that, your two main options are emissions compliant tuning or delete.
Option 1. Emissions compliant tuning claims to offer better MPG, longer distance between regen, more power, etc etc.
Option 2. Delete = No regen. Nuff said.
Also now that Black Friday and Christmas are around the corner, it's very likely these companies and eBay will have some sort of sale so check their social media or sign up for emails. If you go route 2, you might want to hurry because of the crackdown. There are still a few sites that offer delete tuning.
Good luck and let us know how it's going.
I have never felt one in my F250. But the VW Golf TDI I had would "cough" when I was sitting idle at a stop light. Was perfectly normal.
The only valid reason I've seen someone have to worry about it was when they were driving their truck on the farm in high grass and didn't want to start a fire.
People should just drive more and worry less.
I monitor the EGTs for more than just regens. I look for temp consistencies which can indicate issues with the exhaust system. There are several other PIDs that I monitor is a part of my preventative maintenance in all my vehicles. And besides I like monitoring the truck's performance.
Last edited by Work Truck Fanatic; Nov 16, 2019 at 05:34 PM. Reason: additional wording
Folks have been fussing about this for ages. I don't even pay attention to the regen process. If Ford thought it was a big deal to interrupt it, they should have put a warning on the dash to not turn the truck off.
It would be bad for business if they built a truck that could make 1 million miles. Sell more trucks make more profit! When it breaks make more profit. Do you really think FoMoCo is looking out for the consumer?
I have an OBD bluetooth adapter that streams data to an 8 inch tablet and monitor about a dozen PID's. Avg regen mileage on my 2017 is every 480 miles. It doesn't always regen to zero every time when if I keep going and don't shut off during active regen. It also has a passive regen cycle. I have seen regens last 20 mins and others last 45 mins. My truck is a dually and usually towing when I drive it. 12,000 of my 15,000 miles are towing
