#!@$#@$#@$@#!@ REGENS
Old Nov 25, 2019 | 05:30 AM
  #61
Blazn's Avatar
Blazn
Originally Posted by schrod
Lots of luck with that. I had a 5 Star custom tune on SCT tuner and they promised increased mpg's and longer times to regen. Bull**** did NOT happen. This was on my 2016. I did get better throttle response and more power but I did not need more power!
I figured that would be the case but I had to try to be objective and mention all options to OP. Frankly, I always thought emissions on tuning would be bad for regen and MPG since the tuning probably dumps more fuel to increase power but the extra fuel also means more soot that accumulates in the DPF thus requiring more frequent regens to clean DPF which also results in lower mpg. It's similar to how running the highest tune on a deleted truck would result in more black smoke, due to more fuel, compared to a low hp tune but at least the soot can exit the tailpipe as opposed to getting trapped in the DPF. IDK if this logic is correct or not, maybe somebody can chime in, but it's how i've always perceived it to work.
Old Jan 5, 2020 | 08:51 AM
  #62
cpobst's Avatar
cpobst
I just completed an OCR, 453 miles since my last regen. I will say that i have seen a fairly large increase in mileage between regen and the regens seem to complete quicker. Ive ran 5 or 6 tanks through now using Better Diesel FBC and I am a believer.
Old Jan 5, 2020 | 04:09 PM
  #63
speakerfritz's Avatar
speakerfritz
120 between regens is suspect to me
i would use a cetane boost additive, question the oil brand I am using, have a service department verify my glow plugs are working....glow plugs are used during cold weTher beyond starts, and check my air fitter .
also keep fuel in tank above 1/4 since below 1/4 fuel sloshes and could lead to air entrapment
also check tires for correct psi.
something is not right ....you should investigate further.
Old Jan 5, 2020 | 04:13 PM
  #64
senix's Avatar
senix
my latest regen was 652 miles. All good ideas to check and look at.
I keep my idling to a bare min. and usually don't drive in traffic. Try to do that too.
talk2cpu
6.7L Power Stroke Diesel
24
Jul 17, 2019 05:11 AM
adbscu
Aug 15, 2016 05:45 AM
05F250DSL
Apr 8, 2015 02:30 PM
Amelio
16
May 9, 2014 05:41 PM
caddy
6.4L Power Stroke Diesel
Jul 12, 2011 08:58 PM
