Decode
Old Nov 11, 2019 | 04:09 AM
Josep66's Avatar
Josep66
Decode
Hi guys,
would you please ease assist me decoding those numbers.? Found the buck tag and some details I do not recognize. Maybe you can help or address to a site we’re I can decode.
Also, the engine decal would be nice to decode.
Thank you.
Old Nov 11, 2019 | 06:25 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Buck tag can not be decoded according to Number Dummy. He might know some engine codes.
Old Nov 11, 2019 | 07:11 AM
73GreenBean's Avatar
73GreenBean
Just from looking and assuming (which this disclaimer is nothing more than an assumption so I don't get ) I see things like A/C, Mid and Aft tanks, 133" wheelbase, those are just guessing at what all that means I'm sure I'm wrong. Other numbers are factory codes used by workers to assemble various components according to what the DSO ordered the truck for
Old Nov 11, 2019 | 08:44 AM
Josep66's Avatar
Josep66
Looks all you say are not guessing as all matches with my car.! So we are in the right way.,! Thanks.!
Old Nov 11, 2019 | 03:21 PM
1TonBasecamp's Avatar
1TonBasecamp
Does the truck still have it's warranty plate riveted to the driver's door? If so you can confirm or deny the existence of the other numbers.
Paul
Old Nov 11, 2019 | 03:30 PM
Josep66's Avatar
Josep66
Paul
Yes, I have it and that’s the reason I said it matches.
Old Nov 11, 2019 | 05:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Buck Tag vs Warranty Plate: The wheelbase and the COLOR codes match, nothing else matches including the VIN (Warranty Number).
F10 = F100 2WD Pickup.
H = 390 2V
R = San Jose CA Assembly Plant // Buck Tag has a P instead of the R
R84118 = 1973.
133" Wheelbase.
X8: X = Light Goldenrod // 8 = Yellow.
F105 = F100 2WD Pickup, 5500 lbs. GVWR
L 4: L = Medium Ginger Vinyl & Medium Ginger Cloth - Ranger XLT // 4 = Styleside Pickup box.
G = C6 Automatic Transmission.
H2J: H2 = Ford 9" Rear Axle / 3.50-1 / Limited Slip / 3,750 lbs. Axle Capacity // J = Power Steering.
5,500 lbs. Gross Vehicle Weight Rating.
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Codes on buck tags were used by assembly line workers to assure the correct parts were installed that matched the build sheet.
These codes cannot be decoded unless they match codes on the Warranty Plate.
But the sequence of codes stamped on the buck tag are not the same as the Warranty Plate, so decoding these without a Warranty Plate would be almost impossible.
Old Nov 12, 2019 | 12:05 PM
Josep66's Avatar
Josep66
Thanks for the info. I already knew the Warranty Plate data but wanted to know if someone could help with data in the buck tag as WDE, WLD, RKR, HX, etc..
I say it matched because the 2-3 notes 73GreenBean mentioned, A/C, dual tanks and 133” were correct for my application.
yes, I also noticed that there is a P instead of an R in the buck tag and Warranty Plate, is that correct or should be an error.? Guessed it should be the same R in both places.!
Thought for 1973, X8 meant Durango tan with Tampico Yellow, haven’t seen that Light Goldenrod before...
Anyways, I appreciate your feedback very much, thanks.!
Old Nov 12, 2019 | 02:21 PM
NumberDummy
The difference in color names has to do with promotional names for colors that are shown in sales brochures.
Parts catalogs list the actual colors, not promotional name colors. Each color has a basic part number next to it.
8 = Yellow = Basic part number: 3341 - touch up paint: AE60-3341-A 3 ounce can w/brush.
X = Light Goldenrod = Basic part number: 3565 - touch up paint: AE60-3565-A 3 ounce can w/brush.
DuPont, Sherwin-Williams and other color charts have a 'chip' (picture) of the actual color, the COLOR code and the Ford basic part number.
btw: X for 1976/78 is Tan, basic part number: 5441
The above info is from the 1973/79 100/500 series Ford TRUCK parts catalog, not the 1973/79 Ford car parts catalog.
Old Nov 13, 2019 | 03:28 AM
Josep66's Avatar
Josep66
Thank you Sir, lots of good information.!!
Old Nov 14, 2019 | 04:02 PM
Josep66's Avatar
Josep66
Any chance to decode this numbers/letters here.? Thanks
[/QUOTE]
Old Nov 14, 2019 | 04:13 PM
73GreenBean
[/quote]
Definitely a ford valve cover...do you know if the engine is original to the truck ( id assume it is since the rest of the truck looks original) but if it's not that sort of looks like something autozone or another crate engine company would put on their rebuilds as far as I know those numbers cannot be decoded as they are codes that are not in database storage for us to look up. Those may be dating numbers, batch numbers for the cover, style numbers or other non important numbers. Honestly I wouldn't worry about them as they are not important other than be curious. Most are usually burnt off from all the heat the engine puts off or peeled off due to rain and just plain being 40+ years old
caravaggio2000
Jan 5, 2019 09:47 AM
farmergary
Feb 1, 2017 09:26 PM
Santiagoeford
Jul 18, 2015 11:26 AM
Nicholas B
25
Apr 28, 2015 07:37 AM
divcotruck
Sep 29, 2013 10:39 AM
