Sponsored by: Real Truck
Ignition problem
Old Nov 10, 2019 | 01:42 PM
Big-1's Avatar
Big-1
Ignition problem
Okay gents,
I need your help. 2007 Ford F-350 King Ranch PSD 4X4 with 240,000 miles. I am having a problem about every 10 starts. Very sluggish starting about 1 in 10 times. Just had to get a jump, let the truck run for about an hour, seems fine. Does this truck have an ignition module on it or should I just change the starter? I have had it bulletproofed and replaced batteries, and alternator. Had the truck for almost 6 years and 185,000 miles. Never changed the starter. What words of wisdom can you folks put on me? Thank you in advance.
John
Old Nov 11, 2019 | 09:09 AM
Fefanatic's Avatar
Fefanatic
Your description isn't clear. Is it cranking slow? Does it crank a long time before starting? Does it run rough after the start for a few minutes? FWIW, there is no ignition module. The cop's are fired by the ecm and depend on signals from crank/cam sensors.
Now if you are having intermittent crank issues then it would be wise to check battery and all connections to battery including frame ground. If it is a hard start issue I would be replacing spark plugs and fuel filters. Be more specific with your questions and we can help better.
Old Nov 11, 2019 | 11:03 AM
Djosbun's Avatar
Djosbun
I would perform a voltage drop test on both the positive battery cable as well as the negative cable. You will need a digital voltmeter to perform this test. It is very easy to do and you can quickly learn how by doing a quick YouTube search.
-- Dave
Old Nov 12, 2019 | 07:29 AM
Big-1's Avatar
Big-1
It's early in the process of tracking down the problem, but I opened the fuse boxes and pushed everything down. I don't know. Electrical is an issue.
Old Nov 12, 2019 | 07:49 AM
Big-1's Avatar
Big-1
About 1 time in 10, it will crank slow. Drives me nuts. I had to get a jump on a job site. Let the truck run for a long time. Every time since, fired fine. Driving me nuts!!! Got almost 240,000 miles. Drove back to Mobile from Manassas, VA yesterday. Flawless trip. Fired strong EVERY time I started it. We will see today.
Kenneth Spivey
23
Apr 3, 2018 10:51 PM
73FordF100
61
Aug 24, 2017 01:13 PM
AZ_Ford_Guy
13
Aug 27, 2012 11:51 AM
pssinfo
Nov 29, 2011 08:13 AM
troyboy38
Feb 3, 2008 01:22 PM
