1986 f150 starting issues
Old Nov 6, 2019 | 03:31 AM
Andrew_f100's Avatar
Andrew_f100
Hey guys I have a 1986 f150 with a 351w I recently had the entire motor rebuilt from top to bottom and now it won't start, it has a very slow crank and seems lifeless, I've tried different batteries I've tried brand new batteries and still no luck, a few people said it could be the starter due to the motor having more compression now and I would need a more industrial starter but that doesn't sound right, anybody have any clues?
Old Nov 6, 2019 | 09:39 AM
Kramercd's Avatar
Kramercd
Timing could be too far advanced. Could also be a vacuum leak. Or read this before kr98664 pops in, because he's going to make you go read it anyway lol.
Old Nov 6, 2019 | 03:29 PM
kr98664's Avatar
kr98664
Darn tootin! Follow that troubleshooting guide. The test procedure disables the ignition, so it takes that completely out of the picture. If you have a starter that is slow to turn, or won't turn at all, that guide will pinpoint the exact fault.
Old Nov 6, 2019 | 05:51 PM
matthewq4b's Avatar
matthewq4b
To rule out timing just pull the coil wire and try cranking it over. If it cranks over fine it was timing. If not you may have a weak starter and the higher compression has now highlighted the issue.
Also be sure your cables are in good shape and the connections are sound.
Titus Ford
Apr 13, 2019 12:23 AM
Renegade_7
13
Sep 3, 2017 02:03 PM
vboxingguy
26
Apr 14, 2012 06:37 PM
stepsidenewbie
Mar 3, 2012 11:28 AM
IH82LUZ
Oct 17, 2002 10:26 AM
