Starter help please
Old Oct 15, 2002 | 10:00 AM
IH82LUZ's Avatar
IH82LUZ
Starter help please
I am test driving a 1987 F-150, 2WD, straight six this week.
It is very slow starting. In my opinion it sounds as if the starter is dragging. The owner has had it for only a few weeks and suggested that the timing is turned down too low.
When you turn the key it turns the motor very slowly for a few turns and then picks up and cranks. It hasn't failed to start yet. It seems to be worse on hot starts than cold starts. In my limited experience that usually means starter.
Any thoughts?
Starter or timing?
Old Oct 15, 2002 | 01:14 PM
SPROCKET's Avatar
SPROCKET
Starter help please
definately sounds like the starter...starters hate the heat...also something to think about would be a fuel pump.
Old Oct 17, 2002 | 09:33 AM
IH82LUZ's Avatar
IH82LUZ
Starter help please
I have since found out the truck is an 89.
The only thing I don't understand is how can timing cause the motor to turn slower when starting. If it was turning over but not starting I could understand.
I am an amateur but I am just curious.
Old Oct 17, 2002 | 10:26 AM
TallPaul's Avatar
TallPaul
Starter help please
