03 Excursion P0278 and leak
Old Nov 9, 2019 | 06:40 AM
SmackDaddy's Avatar
SmackDaddy
Originally Posted by Frosstyx
Im going to run this **** out of it tomorrow. If it has a problem, hopefully it will show climbing the Blue Ridge Parkway for 3 hours.
I sent you a PM. I have a like new OEM Donaldson air filter and the whole assembly with updated Motorcraft intake tube with clamps etc. plus some other parts if you are interested. I was in my shop looking for a box yesterday and ran across it and thought of this thread. These Donaldson filters are good for a very long time and hold a lot of debris. I had this one on a couple of months after replacing it and had to step up to more air flow with an S&B Stage 2 to satisfy my larger turbo.
Old Nov 11, 2019 | 11:11 AM
Frosstyx's Avatar
Frosstyx
So, I set up a pressure test... the Saga continues, It will hit 20psi before dropping down to 16 where it stays due to degas cap relief.
My question is, should I be worried about anything else with this thing if I got with new heads and oil cooler. Imma replace push rods as well. Any other wearable items I should look at? Im assuming if I havent had any issues with lifters and whatnot that the lower end of the engine is in good shape? Anywho, Im ordering heads today from KDD.
Amicus
May 19, 2019 09:43 PM
Elijah Doub
Jan 13, 2017 08:12 PM
Thomas Booth
Apr 9, 2014 08:34 AM
dletourneau3
Jan 2, 2014 03:55 PM
BIGGPIGG4x4
Dec 21, 2010 10:53 PM
