Sponsored by: Real Truck
Blower motor resistor
Old Nov 1, 2019 | 11:37 PM
fordmod21's Avatar
fordmod21
Can someone tell me where the blower motor resistor is on a 2012 f 250?
Old Nov 2, 2019 | 12:31 AM
AUTOHAUL's Avatar
AUTOHAUL
Had a 2005 F250 Lariat that broke the heat/ac fan hamster wheel which jammed. When I tried to free it the fan rheostat burned up. Now this was an automatic fan controller and was mounted on the fire wall near the fan. Back in 2008 cost was about $40. Not sure if the XL or XLT are in the same place.
Old Nov 2, 2019 | 04:34 AM
Just Strokin's Avatar
Just Strokin
There is not a blower motor resistor. There is a blower motor controller that controls the variable fan speed. It is mounted on the back side of the HVAC box that requries the HVAC box to be removed to replace it.
Old Nov 2, 2019 | 07:17 AM
projectSHO89's Avatar
projectSHO89
Does not apply to the OP's truck or question.
As Larry said, you have to pull the whole HVAC box. That means evacuating the A/C system, draining coolant, and pulling the whole dash to get to the HVAC box so IT can be removed. Hate to see the bill for this repair from a dealer....
BTW, the actual Motorocraft blower speed module is under $50 at RockAuto if you can DIY the above.
EconolineFan
Mar 13, 2012 02:36 PM
twowheeled
Aug 23, 2011 10:30 AM
dogg16
Bronco II
Jun 14, 2007 11:35 PM
thefuzz472
May 21, 2007 06:34 PM
coppadab
Jun 9, 2005 11:06 AM
