blower motor??????
Old May 20, 2007 | 11:26 AM
thefuzz472's Avatar
thefuzz472
Question blower motor??????
1991 f-250 7.3
the heat/ac fan motor will only work on high.
do i need to replace the blower motor or is it the control switch?
Old May 20, 2007 | 12:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There is a resistor that is mounted in the heater air box.
Not sure where it is located on the 91 model, but that resistor is what gives you the lower fan speeds.
Old May 20, 2007 | 01:59 PM
PLC7.3's Avatar
PLC7.3
Check in the engine compartment on the front of the plenum chamber, between fan and A/C....
Old May 20, 2007 | 02:30 PM
thefuzz472's Avatar
thefuzz472
what am I looking for?
what does it look like?
Old May 20, 2007 | 07:15 PM
PLC7.3's Avatar
PLC7.3
The fan gets power........the other thing on that power line is the resistor screwed to the plenum.....
Old May 21, 2007 | 12:11 AM
typefour's Avatar
typefour
A 4 wire plug is to the center of the truck by the blower motor, unplug, take out 2 screws and there in your hand is the resistor. If that does not fix it the switch is bad. There are 2 resistors available, the difference is the thermal protector, I have used whichever is available and there is no difference in operation. my 2 c
russ
Old May 21, 2007 | 06:29 PM
Winger235's Avatar
Winger235
The location and part number was the same for my 93 and my 88. The resistors need the air from the blow to keep cool or they will burn out. If you go to Carquest or whereever hope you know the parts guy the part is around 30 bucks list.
Old May 21, 2007 | 06:34 PM
F250FarmBoy's Avatar
F250FarmBoy
There is a pic in my galley under "Tank"
I think its the 14th pic down.
It is circled in red.
