Sponsored by: Auxito
Will this injector work ok?
Old Oct 31, 2019 | 12:52 AM
traildad's Avatar
traildad
I broke a little off an injector while removing the lower o ring. I think it will be ok as is. Is the cap just a o ring retainer? Will this cause a problem?
Old Oct 31, 2019 | 09:05 AM
Stonedpony's Avatar
Stonedpony
NO, if the hat comes off guess where it is going? Change the hat out on it or go to a junkyard and get another one. The reason I said junkyard is they are cheaper and you still have to change the o-rings. Or you can order one online.
Old Oct 31, 2019 | 09:53 AM
alloro's Avatar
alloro
Absolutely not, you need to replace it. The rest of that plastic tip will break and fall into the cylinder. Once the tip is gone the fuel spray pattern will be non-existent and the cylinder will not fire correctly.
Old Nov 1, 2019 | 12:23 AM
traildad's Avatar
traildad
Ok thanks. How do I take the hat off? Screw or pry?
Old Nov 1, 2019 | 11:54 AM
alloro's Avatar
alloro
You don't, it's molded onto the injector. You need to replace the whole injector.
Old Nov 1, 2019 | 11:05 PM
traildad's Avatar
traildad
Stonedpony said you can replace the hat. I’m pretty sure autozone sells an o ring kit with a new hat so I think they can be replaced. I ended up replacing the injector.
99whiteford
Jun 15, 2019 08:59 PM
tonefordays
Apr 24, 2015 08:19 PM
triplerpos
Oct 1, 2014 10:52 PM
Navyguns
Aerostar
43
Aug 12, 2011 07:46 PM
Pocket
Mar 15, 2007 10:18 PM
