Can it be done?
Old Apr 23, 2015 | 10:23 AM
tonefordays's Avatar
tonefordays
Can it be done?
Hey guys,
Is there any way to use a Scangauge II to monitor injectors, other than the misfire monitoring? I suspect I have a dying injector due to some white smoke and I hate to spend $100+ to do a 5 minute contribution test. Are there any specific x-gauge commands I can use?
Thanks
Old Apr 23, 2015 | 10:25 AM
npccpartsman's Avatar
npccpartsman
unfortunately NO. The misfire counts don't work AFA everyone here has been able to determine.
Old Apr 23, 2015 | 10:29 AM
tonefordays
Crap....that's what I was afraid of.
Thanks
Old Apr 23, 2015 | 11:23 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's the codes as origonally posted if you want to try. As Tim said I haven't heard of anyone having much luck with the misfire count though.
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
Fuel Injector Pulse Width (microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Fuel Injector #1 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3001
MTH: 000100010000
NAM: FI1
Fuel Injector #2 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3101
MTH: 000100010000
NAM: FI2
Fuel Injector #3 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3201
MTH: 000100010000
NAM: FI3
Fuel Injector #4 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3301
MTH: 000100010000
NAM: FI4
Fuel Injector #5 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3401
MTH: 000100010000
NAM: FI5
Fuel Injector #6 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3501
MTH: 000100010000
NAM: FI6
Fuel Injector #7 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3601
MTH: 000100010000
NAM: FI7
Fuel Injector #8 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3701
MTH: 000100010000
NAM: FI8
Quote:
Originally Posted by DieselStroke
He is working on an injector misfire count right now that should tell us if there is an injector that is performing worse than the average!
Here's what I have for misfire counts.
Cylinder #1 cumulative misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 cumulative misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 cumulative misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 cumulative misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 cumulative misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 cumulative misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 cumulative misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 cumulative misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
Old Apr 23, 2015 | 11:39 AM
tonefordays
Thanks Rusty, I'll give those a try this weekend and see if I can come up with anything meaningful. I've had the misfire settings in my SGII for a long time, but have never had anything detected, even when I did have a bad injector a few months ago. I'll need to double check to see if the settings are the same as what I have set up. That's a whole lotta numbers to set up, so it might take awhile...
Old Apr 23, 2015 | 01:53 PM
lupuseven's Avatar
lupuseven
I know the torque pro's misfire count at each cylinder is good. $40 vs $100 and you get more stuff too, that is if you have the time to wait the Blutooth adapter to come in
Old Apr 23, 2015 | 02:01 PM
tonefordays
Will it do contribution test?
Old Apr 23, 2015 | 02:25 PM
lupuseven's Avatar
lupuseven
Just looked at all the options did not see it. But it does have misfire count for each cylinder.
It is "accurate" replaced the offending injectors at those cylinders and misfires went away. Granted bad injectors are not the only thing to cause misfire readings.
you could do a bubble test too lost of work but also effective. When i get home I'll post link
Sent from my Farnsworth using IB AutoGroup
Old Apr 23, 2015 | 03:01 PM
tonefordays
Thanks for the info.
Old Apr 23, 2015 | 08:25 PM
cheezit's Avatar
cheezit
Try disconnecting one at a time. Wait for the smoke to stop. Replace that one.
It may or may not work depending on how it failed.
Old Apr 24, 2015 | 07:31 AM
tonefordays
Thanks Cheezit
Since I only notice the smoke driving off from a stop, after the engine is fully warm, will I be able to drive it short distances to look for smoke, with an injector disconnected? Other than there being a miss in the idle, are there any other things I need to be aware of before trying this?
Thanks
Old Apr 24, 2015 | 07:28 PM
cheezit's Avatar
cheezit
Nope, ive driven them around the block running on one bank before
Old Apr 24, 2015 | 08:19 PM
tonefordays
That's good to know, I'll have to give this a try.
Thanks!
triplerpos
Oct 1, 2014 10:52 PM
RKCORPS25
Nov 1, 2013 09:34 AM
seth1
Jan 31, 2012 06:24 PM
renchr56
Nov 2, 2011 03:21 PM
tjbeggs
48
Feb 11, 2009 11:03 AM
