Cab Clearance Lights
Old Nov 2, 2019 | 06:41 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I had the original OEM cab lights on my truck when I bought it. They were faded, clouded and a couple of bulbs burnt out.
I did want to remove the base from the cab and break the factory seal. Thankfully, I bought LED bulbs and new covers to fit on the PEM base.
They have been on there for 5 years now and still look great.
Only the cover is/was available at the time and they came in several colors. If you have a leak or just want different shaped housings, I would suggest new housings. If you only want to freshen the cover up or change the color, go that route instead.
Old Nov 2, 2019 | 07:02 AM
ajbrown208's Avatar
ajbrown208
Thanks Sous. I think this is the route I'll go. I already decide to Not take down the liner. Some things just do not go back where they were for some people. I'm just wanting mine to work. I got two that are fatigued from the heat of the bulb. I can change them and they last for 2 days to 2 weeks. The LEDs shouldn't get as hot. I'll give it a go.
mudrat025
May 29, 2016 12:18 AM
peka
15
Dec 4, 2015 03:28 PM
1984F2506.9
Jan 12, 2014 11:58 PM
CityGuy24
Mar 14, 2009 12:26 AM
79beater
Dec 6, 2002 09:54 AM
