Cab Clearance Lights
Old Oct 30, 2019 | 07:15 AM
ajbrown208's Avatar
ajbrown208
I have some new LED cab clearance light to install. Anyone know how the old ones come off?
Old Oct 30, 2019 | 07:39 AM
Colorado350's Avatar
Colorado350
Pull the liner, 2 iirc 10mm nuts, light lift up. The biggest concern is making sure you have a good seal (gasket) between roof and bottom of light.
Old Oct 30, 2019 | 07:57 AM
ajbrown208's Avatar
ajbrown208
Thanks man. I've got something that will seal for sure. This stuff is amazing.
Old Oct 30, 2019 | 08:09 AM
bwguardian's Avatar
bwguardian
Not sure why you would want to pull the liner when all you have to do is remove the one screw in the back of the lens, then flip it forward to expose the bulb.
Old Oct 30, 2019 | 08:10 AM
Walleye Hunter's Avatar
Walleye Hunter
How is the liner held in? How is it removed?
Old Oct 30, 2019 | 08:43 AM
Colorado350
The tube says 400* that’s IMO that’s not rated high enough. The roof easily gets hotter than that sitting in direct sunlight. If the stuff starts to melt it leak down and eventually you’ll have a water leak. I would use gasket making material or OEM.
I’m assuming he’s replacing the whole fixture and not just the bulb. If he’s just replacing the bulb then yeah just pull the cover off.
NOTE: OP seal the seams on the new LED’s with a clear sealant (silicon will work here) or you’ll most likely end up with moisture in them very quickly. I have replaced the fender marker lights on my Dually several times. Every one I bought got moisture in them until I sealed the seams on the last set. The clear silicon goes on white and drys clear so you can see where you’re putting it.
Old Oct 30, 2019 | 09:12 AM
ajbrown208's Avatar
ajbrown208
I am replacing the entire fixture. So the line needs to come out. I do disagree with the temperature of the hood or cab reaching 400° F in direct sunshine light though. I recently resealed the oil pan. I didnt get enough OEM sealant at the very front of the pan. It leaked a little oil but only at higher than idle rpm's. I used some of this sealant after cleaning as much metal as possible with denatured alcohol. That was 10 days ago and still no leaks.
Old Oct 30, 2019 | 01:54 PM
Shovelheadrob's Avatar
Shovelheadrob
Remove the pillar trims, door seal rubbers, overhead console pulls off, remove sun visors, then the liner will pull down. I think that's everything.....
Old Oct 30, 2019 | 05:43 PM
Walleye Hunter
Thanks, is it just held in with clips like the pillar clips?
Old Oct 30, 2019 | 07:11 PM
Dan V's Avatar
Dan V
Next time I'm rolling down the road on the summer, and get hungry, I'm just cook myself a pizza.....on the roof.
Old Oct 31, 2019 | 05:00 AM
Shovelheadrob
The overhead console is on clips, you have to be quite forceful with it.
There are no clips retaining the head liner.
Old Oct 31, 2019 | 06:56 AM
Walleye Hunter
How's it stay up there?
Old Nov 1, 2019 | 06:54 AM
MiamiPSD's Avatar
MiamiPSD
What LED lights are you going to install? I have the original motorcraft lights which are dulling out and my thoughts are also to change out.
Old Nov 1, 2019 | 07:23 AM
ajbrown208's Avatar
ajbrown208
I have had these for years.
Old Nov 1, 2019 | 12:43 PM
Shovelheadrob
Reverse gravity.....
No seriously all the other stuff keeps it in place.
