1995 F150 O2 Sensor
Old Oct 29, 2019 | 03:41 PM
Flamin5.0's Avatar
Flamin5.0
1995 F150 O2 Sensor
My 1995 f150 4x4 5.0l is SD, I am however unsure if it has a o2 sensor. The reason I am asking is because I would like to purchase and install long tube headers. Also, would I be able to run gt40 heads with sd or not? If so, do I need a new cam?
Old Oct 29, 2019 | 03:52 PM
Conanski's Avatar
Conanski
You can do headers and a mild EFI friendly cam, or heads and headers, but not all 3. Your truck will have one O2 sensor at the Y pipe junction and it must be reinstalled in the exhaust after the headers are installed, with longtubes it is recommended you place it in the passenger side collector.
Old Oct 30, 2019 | 07:58 AM
Flamin5.0's Avatar
Flamin5.0
Ok, since I can't do all three, am I able to have the e7 ported and run a cam with long tubes? Also, is there such thing as medium length tubes? I realized that with offroading, long tubes would be risky.
Old Oct 30, 2019 | 08:16 AM
timbersteel's Avatar
timbersteel
What transmission do you have?
Reason I ask is that most '95, 5.0 trucks were MAF and they came with a 4R70W. Some were special with an E4OD transmission and could be SD.
Old Oct 30, 2019 | 09:14 AM
Conanski's Avatar
Conanski
No, ported heads present the same problem as bigger heads do.. too much airflow for the stock injectors.
Shouldn't be, longtubes of any quality(not flowtech or Hooker) won't hang any lower than the radius arm brackets.
Old Oct 30, 2019 | 11:11 AM
Flamin5.0's Avatar
Flamin5.0
M5od i believe, its a 5 spd
Old Oct 30, 2019 | 01:22 PM
Mudsport96's Avatar
Mudsport96
Same boat I am in, 5 speed makes you speed density. Could always look for a mustang wiring harness and swap to maf. That way you could do more down the road
Old Oct 30, 2019 | 01:28 PM
Flamin5.0's Avatar
Flamin5.0
Never heard of swapping to a stang harness? Have you done it? Also anyone here know what in the crap a mega squirt is? And does anyone have a pimp xs computer? What's your thoughts
Nally427
Dec 1, 2010 01:10 PM
riodeal5.0
Sep 4, 2007 08:45 AM
Trav460
Apr 16, 2007 10:15 PM
harley
Apr 16, 2002 05:53 AM
