starting problem
Old Oct 28, 2019 | 06:53 AM
akpolaris2's Avatar
akpolaris2
starting problem
1997, f-350, 7.3 ltr with approx 200,010 miles. I haven't run the truck a lot and recently tried to start it and believe the batteries may need replace. They certainly need a charge. I have a remote start on the vehicle. Utilizing the remote it was cranking but batteries were running down. I tried to turn the key and got nothing, not even a click. Charged the batteries a bit and got some cranking from the remote but again nothing with the key start. I am out of town and will be home soon. Plan on charging and testing the battery's but am confused by the no response from the key.
Old Oct 28, 2019 | 08:10 AM
Jarrett Campbell's Avatar
Jarrett Campbell
I would charge the batteries up and try the key again. If there is very little charge, the truck won't even turn over.
Old Oct 28, 2019 | 10:43 AM
PSU4ME's Avatar
PSU4ME
It’s possible there is a problem with your pcm if the truck won’t turn with the key.
Old Oct 30, 2019 | 05:51 PM
akpolaris's Avatar
akpolaris
I hate the acronyms, what is a PCM?
Old Oct 30, 2019 | 06:09 PM
z31freakify's Avatar
z31freakify
Power control module aka the computer for the truck
Old Oct 31, 2019 | 10:55 AM
akpolaris's Avatar
akpolaris
o the battery's took charge and using the remote I got it started, ran very rough. Shut off and won't start again. Still nothing using the key switch. Where to look for that prob? The switch on the fender
Old Oct 31, 2019 | 02:41 PM
Hit Man X's Avatar
Hit Man X
What is the CCA rating of each batt? Age? Terminals and such clean? Age of starter?
Sounds like batteries are on way out.
Old Nov 3, 2019 | 04:25 PM
akpolaris's Avatar
akpolaris
Battery's are serviceable. I can get the truck started with the remote start. How can this PCM be tested? I replaced the solenoid on the fender thinking that might be the problem but still nothing when I turn the key. Rock auto lists an ICM; ignition control module and ecm,; engine control module and a ficm; fuel injection control module
Old Nov 3, 2019 | 04:37 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Bypass the remote start by fuse removal or whatever.
Key on, engine off WITH THE KEYS, then jump the solenoid at the fender and let me know what happens. Does it just crank only or click and nothing?
Still no answer on the starter age.........
Are you currently in Alaska? If not, where?
Does not sound like a PCM, nor an IDM issue to me if it actually runs at times. Sounds like a sensor issue or the truck just is not cranking fast enough to light off. What time of day are you trying to start it? Ever tried to plug it in? Do you even know if your glow system is working?
Old Nov 3, 2019 | 05:27 PM
PSU4ME's Avatar
PSU4ME
Agree that it’s likely not either computer if you get it running with the remote start.
To be honest, I was surprised to hear about a remote starter on a diesel truck. I’m sure they have them but I’ve never heard of them on an OBS. Regardless, I think your non start issue could be related to the remote starter. Have you thought of removing it all together?
tfsiii
Jul 6, 2018 07:20 PM
danwelle
2009 - 2014 F150
Dec 12, 2016 08:01 PM
HwyXingFrog
2004 - 2008 F150
Jul 23, 2012 11:35 PM
mauro12
Jul 21, 2011 09:17 PM
corzolek
May 3, 2005 04:07 PM
