Sponsored by: Real Truck
starting issues
Old Jul 20, 2011 | 09:02 AM
mauro12's Avatar
mauro12
starting issues
So I have a 99 F250 with a 7.3 Diesel. Just recently it will not start using the key. If i cross the terminals on the solinoid it will start or if I use the remote start it will start or also if I push the remote start button then turn the key it will start but if I just turn the key wait for glow plugs then turn key to try starting it then it will not work. Any suggestion?
Old Jul 20, 2011 | 04:08 PM
projectSHO89's Avatar
projectSHO89
Define "Will not start".
Old Jul 21, 2011 | 01:17 PM
mauro12's Avatar
mauro12
I turn the key and absolutley nothing happend it wont roll over or click nothing but if i use remote start it works fine. I figured it was the ignition switch but that didnt fix the issue at all.
Old Jul 21, 2011 | 09:06 PM
BigAlsPSD's Avatar
BigAlsPSD
Check out the links in this post, https://www.ford-trucks.com/forums/1...l#post10099133 maybe they will help, I'm not familiar with the way remote start works, but could be just linkage adjustments. Have you tried with the key to start with it in neutral?
Old Jul 21, 2011 | 09:13 PM
mauro12's Avatar
mauro12
ya I have tried neutral also and it wont work either
Old Jul 21, 2011 | 09:17 PM
BigAlsPSD's Avatar
BigAlsPSD
Well sorry it wont help much then. I would have to say you need to find out if you have voltage going to the solenoid when the key is turned? I feel like it is going to be a wiring issue.
rtf505
74
Feb 4, 2015 05:10 PM
kevindsingleton
Nov 22, 2014 11:29 AM
Painted Horse
6.7L Power Stroke Diesel
Oct 30, 2011 12:19 PM
shelbyera
2004 - 2008 F150
Mar 17, 2010 09:13 AM
ssjrsw
Jan 22, 2006 07:09 AM
