Won't crank - fully charged
Old Oct 25, 2019 | 03:57 PM
snafuF250's Avatar
snafuF250
Trailering
86 - F250 - 351
This just started out of the blue, battery is charged, reads 13.2V but it won't crank, barely even powers the dash lights up.
BUT if, I put a jump on it and crank it it starts right up and runs fine. What could cause that? Do batteries ever fail where they are holding charge but unable to deliver the requisite current the starter needs?
Never encountered this one before...battery is relatively new (2-3 yrs old), alternator was replaced about 18 mths ago along with starter solenoid.
thanks
Old Oct 25, 2019 | 05:22 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE.
Give this link a look at and it will tell you how to test the system to find what is bad
https://www.ford-trucks.com/forums/1...w-starter.html
But my WAG is a dirty battery connection.
Do you have them battery cable ends that clamp the wire in it?
If so replace the cable(s) now with out even testing them as they will fail at some point like now?
Dave ----
Old Oct 25, 2019 | 05:47 PM
82_F100_300Six's Avatar
82_F100_300Six
you need to load test the battery
get one of those carbon pile cheese graters
Old Oct 25, 2019 | 07:45 PM
Kramercd's Avatar
Kramercd
Check battery connections. If you can get someone to try and crank it while you look at the battery to see if it arcs between the terminal and the connector.
Buddy of mine put two new batteries(not sure how he messed that up) and a starter solenoid on his truck with no luck. When I went to see him(out of state) I cleaned the terminals and reconnected the battery cables and she fired right up. I did happen to be next to the battery which he couldn't do while cranking.
Old Oct 25, 2019 | 07:50 PM
Tedster9's Avatar
Tedster9
Yes that is pretty common. The open circuit or unloaded voltage measurement is a key diagnostic but not as important as a load test. Measure voltage across the posts with the lights on and or cranking the starter.
Old Oct 25, 2019 | 08:07 PM
kr98664's Avatar
kr98664
As Dave has suggested, please run this test. It was written especially for situations like you are experiencing:
It confirms the battery maintains adequate voltage under the heavy load of the starter, and the rest of the circuit is capable of delivering the massive flow of electrons without undue restriction.
As Tedster has mentioned, the unloaded voltage reading doesn't mean a whole lot. It just means the battery isn't totally discharged, that's all. The voltage under load is what's really important.
My hunch is you will find a marginal connection at one of the battery terminals. This restriction was bypassed when you connected the jumper cables. Run the test as detailed at the link above. It will find the fault(s) very quickly.
User 93024
2004 - 2008 F150
Nov 24, 2013 08:55 AM
Johnnymich
Oct 15, 2012 12:28 PM
trueblue123
1997 - 2003 F150
Apr 23, 2011 01:52 PM
seths89f150
15
Feb 24, 2011 05:51 AM
Laddsmith
Jul 23, 2004 01:40 PM
