1999 f250 won't crank all of a sudden, was fine a few hours earlier. Had battery checked, replaced starter and solenoid. Tried starting in neutral. Starter clicks and that's it. Any advice?
if the starter clicks, normally the battery is dead or the ground wires or battery cable is corroded / loose..... hold a volt meter on the battery cables while someone turns the ignition key.
