74 Weak Start
Old Oct 14, 2012 | 07:22 PM
Johnnymich's Avatar
Johnnymich
74 Weak Start
When I go to crank the truck over I get very little response, allmost like the battery is dead. I put it on the charger and same thing, had the battery tested and it checks out ok. Trying to get an idea on where to begin troubleshooting.
Old Oct 14, 2012 | 07:34 PM
jim collins's Avatar
jim collins
My 73 ,302 did that about 2 weeks ago. It was just like a bad battery ,but the battery was new and fully charged. I removed the starter and found it had a brass bushing coming out of the nose of it. The starter was new and had started the engine 30 times at the most. New one took care of the problem.
Old Oct 15, 2012 | 12:28 PM
cowboywanabe's Avatar
cowboywanabe
Posting Legend
Another thing to check... Make sure your battery cables are connected tightly and there is no corrosion at the ends. Also, check where the negative/ground cable connects on the block. I had one that was a little dirty and loose, and it caused the motor to crank slow.
nomadw8
Electrical Systems/Wiring
Oct 25, 2021 10:23 PM
User 93024
2004 - 2008 F150
Nov 24, 2013 08:55 AM
Dustin_86
Jan 7, 2005 11:14 PM
goonski
Oct 10, 2003 09:48 PM
77fromheaven
Apr 2, 2003 02:21 AM
