Hydro boost question
Old Oct 25, 2019 | 08:54 AM
Flitastic's Avatar
Flitastic
My 2019 dually only has 1700 miles and it’s done it since new, so I assume it’s normal but wanted to run it by you all. On cold mornings or cold starts I am getting a slight noise from the steering column. If I turn the wheel just barely the noise either changes tone just a bit or stops all together. Pushing brake pedal has similar results. I came to ford from dodge and LOVINg this truck !! My dodge developed a similar noise at 40k miles. They replaced one of the hydro boost lines that had a defective valve In it. Truck drives , steers, and stops perfectly. Most people driving my truck would never even know it was making a noise but I tend to look for things. Bad habit. lol. Once engine is warmed up usually quiet as a mouse. Thanks !
Old Oct 25, 2019 | 09:58 PM
cangim's Avatar
cangim
When below freezing I get a similar sound when cold, I only notice when straightening out after backing out. I haven’t worried about it at all.
Old Oct 26, 2019 | 07:37 AM
jfritz_drfritz's Avatar
jfritz_drfritz
Not normal.check fluid level.if it is full and still makes noise take it in. Check another truck on your dealers lot. (You are SURE your truck has hydroboost- some models do not - I can’t remember which)
fordman19762003
2015 - 2020 F150
Jan 19, 2019 12:00 PM
Andy's7.3L
Nov 16, 2013 08:26 PM
temuijin
6.7L Power Stroke Diesel
Sep 20, 2012 05:23 PM
jbounds
15
Feb 26, 2011 12:09 PM
shabangles
Dec 27, 2008 09:07 PM
