Name that noise!
Old Aug 17, 2012 | 05:33 PM
temuijin's Avatar
temuijin
Name that noise!
Ford 6.7 noise - YouTube
Old Aug 17, 2012 | 07:50 PM
tolliewolly's Avatar
tolliewolly
I say exhaust
Old Aug 17, 2012 | 10:12 PM
deedsF350's Avatar
deedsF350
does it boost normal and have normal power ?
Old Aug 18, 2012 | 07:03 AM
Hdslider's Avatar
Hdslider
Hi ho off to the dealer it goes. That dont sound good.
Old Aug 18, 2012 | 07:29 AM
ruschejj's Avatar
ruschejj
You mean the sound of an idle turbo or something spinning? It's hard for me to tell what the issue is. Do you think it sounds like a bad turbo bearing?
It could be something in the SCR can too, I'm not sure if it has any moving parts. Maybe the urea pump?
I think you're gonna have to drive the wheels off it to make something fail if you think there's a problem.
Old Aug 18, 2012 | 09:43 AM
screwy's Avatar
screwy
It's hard to tell, and I could be picking up on the wrong noise, but it sounds like the same noise my transmission makes in park after it's warmed up, I thought it was normal... no one else has this?
Old Aug 19, 2012 | 07:17 PM
temuijin's Avatar
temuijin
ford tech says it may posibly be torque converter bad or just noisy hes not totaly sure.... he used those chassis ears to isolate the noise within the bell housing will know more at some point. also this noise is only there when vehicle is fully warm like previous post except this does it in any gear. and always random i can give it some revs to make it go away temperarly. torbo was all ready swaped out 2 months ago. other symptoms are 2 mpg loss when noise is there, 5% to 10% loss in power, exsessive clicking(more then normal under truck.
Old Aug 30, 2012 | 05:56 PM
temuijin's Avatar
temuijin
just to update... tech is replaceing transmission valve body, whatever that is... says the line pressure is all over the place should have it back next week. we shall see.
<!-- / message -->
<!-- controls -->
Old Aug 30, 2012 | 06:00 PM
tolliewolly
Thanks for the update! Keep us posted and good luck
Old Aug 30, 2012 | 11:10 PM
remhaust's Avatar
remhaust
I was going to say sounds like tranny pump or low on tranny fluid,but hard to tell what sound im listening for from video.
Old Sep 20, 2012 | 05:23 PM
temuijin's Avatar
temuijin
valve body did no good... noise still persist... ford dealer now seems scared to look into it any further... makes no sense, if there is a problem that needs fixed. why would they not want to keep touble shooting?
bingo8
EcoBoost (all engine sizes)
Oct 9, 2017 07:41 AM
bawiy1904
Apr 15, 2010 12:33 PM
shabangles
Dec 27, 2008 09:07 PM
scvalone
Jun 9, 2003 03:58 PM
