Dome Light Bulb ???
Old Nov 20, 2019 | 02:41 AM
James Wagoner's Avatar
James Wagoner
Do take some photos when you get one in. I am looking for a replacement LED bulb for the 194 type I have in now that has 5 SMDs. All I seem to find are about 650 lumen and that is not very bright in my cab.
I am seriously toying with the idea of getting one of those RV light housings. If it's too bulky, maybe try to break it down to try and make it flatter. Would have to come up with some other lens cover though.
Old Nov 20, 2019 | 04:07 AM
LongRider's Avatar
LongRider
Originally Posted by James Wagoner
I am looking for a replacement LED bulb for the 194 type I have in now that has 5 SMDs. All I seem to find are about 650 lumen and that is not very bright in my cab..
This is what I am considering:
https://www.amazon.com/dp/B076V9XXW6/?coliid=I25J92M3YC147U&colid=2CLVU8BF3A61T&psc=1&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B076V9XXW6/?coliid=I25J92M3YC147U&colid=2CLVU8BF3A61T&psc=1&ref_=lv_ov_lig_dp_it
I also have an overhead console where I mounted a big clear rectangular generic dome light from Walmart, of all places; I put a 1156-style LED in it and it lights the place up like a stockyards.
I have two of those same Walmart lights in the sleeper, one at each end, with the same LED bulbs and no room in any house is any better lit.
Here are the 1156 that I used:
https://www.amazon.com/dp/B071V2DBWP/?coliid=I184TII9JR5HXQ&colid=3V6X16PD07FP5&psc=1&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B071V2DBWP/?coliid=I184TII9JR5HXQ&colid=3V6X16PD07FP5&psc=1&ref_=lv_ov_lig_dp_it
I have a vintage double aimable map-light also on the console that had little short fat 1156-base bulbs; they provided a little light, but nothing spectacular, and definitely nothing I could read a map by; I put those same LEDs in it and it will burn a hole through the map now.
I have old incandescents in my truck that are 1985-original; the LEDs outperform them in almost every way; I just wonder if they will last as well as the old incandescents.
Old Nov 20, 2019 | 10:02 AM
James Wagoner
Those LEDs will be too high of a color temp for my liking. Want something around 4000K and lower.
It does seem that the basic chrome dome light doesn't have a reflector to bounce the light out of the housing, it's just open in spots.
Old Nov 20, 2019 | 11:38 AM
LongRider's Avatar
LongRider
You are right; there is very little "reflector" area and a big open hole along with some smaller holes; I intend to fix that with some double-sided carpet tape and a piece of Reynolds Wrap; I have used that trick on other lights and it works very well.
Just a few days ago, I had one of my ditch lights off to replace the bulb. The bottom half of the reflector was a bit rusty with all of the chrome flaked off. After wire-wheel cleaning the rust away, buffing the outer housing, and giving the whole works a couple coats of clear lacquer, I applied carpet tape and Reynolds Wrap over the rusty area and worked it down to conform to all the little ripples. Once I got the lens back on, anyone who didn't know could never tell the difference between my fix and a new light.
benutne
19
Nov 28, 2022 10:55 AM
pyro2
13
Sep 27, 2014 12:38 PM
77beater150
Jan 30, 2014 05:57 PM
mmmPowerStroke
Nov 23, 2004 11:59 AM
1968F250LWB
Electrical Systems/Wiring
Feb 2, 2003 06:52 PM
