Dome Light Bulb #
Old Sep 21, 2007 | 08:14 AM
pyro2's Avatar
pyro2
Dome Light Bulb #
What is the bulb type # for the dome light? I swear i've tried 10 bulbs to no avail.
thanks
Old Sep 21, 2007 | 11:01 AM
fatherdoug's Avatar
fatherdoug
The dome light bulb listed in my '78 owner's manual is a 561. I am assuming it would be the same for the '77, if you are talking about the truck listed in your sig.
Old Sep 21, 2007 | 11:02 AM
Mil1ion's Avatar
Mil1ion
Bulb # 561.
Old Sep 26, 2014 | 05:37 PM
lisagoud's Avatar
lisagoud
courtesy dome light bulb 1979 Bronco
Is the light bulb for a 1979 Ford Bronco dome light also a 561? (I know this an old posting but still need the info)?
Old Sep 26, 2014 | 08:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Straight dome lamp, yes, 561.
Dome/map lamp combo, dome lamp 211-2, map lamp 105.
Old Sep 26, 2014 | 10:50 PM
buttwheat's Avatar
buttwheat
I put a clear lens and a LED bulb in mine for under $20 one of the best things I have done to my truck
Old Sep 26, 2014 | 11:55 PM
Ford247's Avatar
Ford247
I have an invisible lense cover. It functions similar to the after market clear lense except you can't see it.
Old Sep 27, 2014 | 08:19 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I had one of those too but somebody stole it .
Old Sep 27, 2014 | 09:20 AM
lisagoud's Avatar
lisagoud
Thank you so much...I will finally be able to see again after dark; I did order a LED one from Amazon but they are saying it is 2 weeks out for delivery so, in the meantime, I guess I need a OEM replacement incandescent..
Old Sep 27, 2014 | 11:14 AM
lisagoud's Avatar
lisagoud
and it worked fine...I thought I had a problem when I put the lamp in and it wouldn't shut off no mater what I did to the headlight switch...then dummy remembered to close the doors and, viola, it works like it should (been so long since I had a light I was confused)
Old Sep 27, 2014 | 11:34 AM
buttwheat's Avatar
buttwheat
Do you have pics of this? where did you get it?
Old Sep 27, 2014 | 11:36 AM
gatorfor88's Avatar
gatorfor88
You cant take a pic of something you cant see
Old Sep 27, 2014 | 11:54 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I had the same problem when I reported mine stolen. The police wanted to know how I knew it was gone .
Old Sep 27, 2014 | 12:38 PM
lisagoud's Avatar
lisagoud
they are readily available for cheap money from Jeff's you know.
tvliftcabinet
Feb 26, 2017 05:06 PM
LT-OPA
New Member Introductions
Jul 8, 2016 06:01 PM
BLACKHAWK_1989
Jan 7, 2016 09:42 PM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Feb 3, 2011 03:07 PM
ptalbert33
Sep 6, 2010 09:37 PM
