Overdrive off is blinking
Old Oct 29, 2019 | 10:14 AM
ChrisS20027.3's Avatar
ChrisS20027.3
Mechanical/internal hydronic failure.
Possible cause ssb or ssc
Originally Posted by ChrisS20027.3
The code pulled is p0782. Shift error between 2-3. Guessing it’s a transmission issue and not sensor
anyone get that code before and what was the outcome.??
782
Old Oct 29, 2019 | 04:59 PM
carl2591's Avatar
carl2591
roger that ,.. good to know.
Originally Posted by Supercab
On top of the rear diff housing.
Old Oct 30, 2019 | 12:46 PM
Supercab's Avatar
Supercab
$20 sensor & 15 minutes time, or $3-$5k trans......I gambled on what everyone said about the sensor on HERE YEARS ago and I won!!
Old Dec 3, 2019 | 11:37 PM
Thedvldog's Avatar
Thedvldog
ChrisS20027.3,
I had my overdrive flashing after a John Wood tow master install. After troubleshooting with John Wood and Dieseltech they found that the speed control OEM connector had two o-rings. This is a defect in the part that slipped through quality control resulting in the connector slipping out just enough to cause the fault. Just something to look into.
Douglas S. Bevan
Sep 22, 2017 11:06 AM
brad3504x4
May 9, 2015 06:36 AM
scav_one19
Jun 26, 2013 08:15 PM
silverbull
Jan 7, 2012 06:27 PM
DadzzTazzDullie
Mar 4, 2008 06:25 AM
