4r100 Reverse problem
Old Oct 24, 2019 | 06:30 PM
DDJC1000's Avatar
DDJC1000
Just rebuilt my 4r100 went through it slow and carefully but when I got it all back together reverse sometime wont work properly, other times it will grab great. Any at all help would be appreciated thanks in advance.
Old Oct 24, 2019 | 08:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My guess is that something is wrong with the seal in the reverse clutch.
Old Oct 25, 2019 | 03:20 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
My guess is the same athough my "street cred" doesn't carry as much weight.
Sorry you will likely have to go all the way back to nearly an empty case to get to it should you choose to just have a look. Since it seems to be intermittent, air checking through the valve body passage may not tell you much.
Old Oct 25, 2019 | 06:07 AM
Walleye Hunter's Avatar
Walleye Hunter
That is a shame considering the work that has to be done to get to it.
f350rebel7788
24
Nov 19, 2021 09:43 PM
elotus
Aug 25, 2011 08:23 PM
Country705
Feb 11, 2007 08:45 AM
