Starter grind
Old Oct 24, 2019 | 12:26 PM
DeputyDiesel's Avatar
DeputyDiesel
Starter grind
Went start my truck today (6.7) after it sat a week and all I got was starter grind. Re tried and it started fine. Normally I would pass it over as a fluke but I’m headed hunting for 10 days soon and don’t need issues. If it is a bad starter would warranty cover it? 23k on it
Old Oct 24, 2019 | 12:37 PM
BK39's Avatar
BK39
Mine has done it twice in 3 years. Hasn't done it in a while now. Truck has 16k on it. I just figured it was a fluke.
Old Oct 24, 2019 | 12:46 PM
C12H24's Avatar
C12H24
It would be covered under warranty. But if it's not doing it regularly, you won't get any love from the dealer on it. They have to be able to duplicate or witness the problem before they can fix it.
It depends upon precisely what the sound is like, but what could be considered starter grind could be the starter Bendix drive going out or the starter drive gear not engaging the flywheel teeth.
Old Oct 24, 2019 | 12:47 PM
speakerfritz's Avatar
speakerfritz
if its under warranty I would schedule it for warranty work.
there is a gear on the starter and a gear on the flywheel mounted in between tranny and engine
the grinding noise could be worn teeth on starter, worn teeth on flywheel,
Old Oct 24, 2019 | 01:59 PM
Texmudder's Avatar
Texmudder
Has happened to me around 5-6 times since 2017.
Old Oct 24, 2019 | 02:30 PM
DeputyDiesel
Well this makes me feel better. Thanks!
Old Oct 24, 2019 | 05:00 PM
Mark198's Avatar
Mark198
How does the computer respond when it grinds? Does it immediately cut the attempt to start or does it grind away until it decides the engine is not starting?
if the computer identifies it I would think the dealership could quickly verify.
Old Oct 24, 2019 | 07:24 PM
zekes66's Avatar
zekes66
My 17 F250 6.7 is on its third starter. I am convinced its something to do with power supply with push button ignition.
Old Oct 24, 2019 | 07:49 PM
C12H24's Avatar
C12H24
Originally Posted by zekes66
...I am convinced its something to do with power supply with push button ignition.
Probably not. It should go without saying that the odds you got three bum starters are pretty extraordinary. I would be looking at a problem with the flywheel or the bellhousing.
Old Oct 24, 2019 | 08:20 PM
DeputyDiesel
it’s woulda kept going until I turned the key back.
Old Oct 25, 2019 | 11:13 AM
BK39's Avatar
BK39
Same here, I hit the button real quick to make it stop. But yes on mine, the truck was off and when I tried to start it, it made the grinding noise. Leading me to believe that the gear wasn't engaged to flywheel before it started spinning.
And like posted above, I didn't take it to the dealer bc it's not happening all the time, and I'm sure they can't do much with it until it does.
79_250RangerLariat
Nov 22, 2010 12:10 PM
A H DEVELOPMENT
Jan 22, 2010 05:21 PM
BroncJMU
1978 - 1996 Big Bronco
Dec 21, 2004 08:20 PM
Egor
1983 - 2012 Ranger & B-Series
Oct 4, 2004 01:28 AM
Dustin_86
May 1, 2004 09:18 AM
