cab mount
Old Oct 23, 2019 | 05:13 PM
charter.pa's Avatar
charter.pa
cab mount
Can anyone give me the exact dimensions of the center point for this mount ? I want to weld in this washer correctly the first time for the proper alignment of the cab bushings.
Old Oct 26, 2019 | 03:35 PM
oldblue79's Avatar
oldblue79
why don,t you just measure the mounting holes on your cab and transfer that measurement to the frame horns you would have to bolt them temporary up to get it correctly then tack it in place then remove and weld.
Old Oct 26, 2019 | 05:51 PM
72rtchallenger's Avatar
72rtchallenger
x2 on this as When I did mine I centered up on top of mounts on frame and measured front to back and side to side on bottom of cab side and pretty much with these patch pieces they center up easily on top of mounts and marked what I needed ,,my cab laid out properly when mounted back to frame
Old Oct 28, 2019 | 03:44 PM
charter.pa's Avatar
charter.pa
The cab is in the storage barn. I need to get the factory location of the hole so alignment of the body will be easier. I did my 68 that way and it never was quite right. Lesson learned. The cab mounts center the cab to the frame with very little side to side adjustment needed.
66with352
Feb 28, 2018 02:33 PM
bjmayberry2
Aug 13, 2017 07:48 AM
jg513
29
Apr 18, 2017 07:29 PM
newguy399
19
Oct 26, 2016 06:16 PM
4x484150
Feb 29, 2016 12:21 PM
