2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Function of this knob?
Old Oct 22, 2019 | 09:33 PM
OldChief's Avatar
OldChief
Function of this ****?
2014 Navigator. Trying to figure out what this **** is for. Below & right of steering wheel. It rotates but nothing happens. Thought it might dim a light, but nothing. No mention of it in the owner's manual. Currently have no back lighting on steering wheel and shifter. Thinking this might tie in with the problem somewhere. Thanks
Old Oct 23, 2019 | 05:33 AM
seville009's Avatar
seville009
Appears to be aftermarket
Did you buy it used?
look behind it and trace the wiring
Old Oct 23, 2019 | 08:09 AM
OldChief's Avatar
OldChief
Just picked this Navigator up a couple of months ago from Insurance auction ( iaai auction ).
Completed body & mechanical work, now working on minor items.
First time I ever owned a Navigator (F-150's and a Expedition in the past), but really happy with this one.
Good point about possibly being aftermarket, I will trace this afternoon. Thanks!
Old Oct 23, 2019 | 08:41 AM
ford390gashog's Avatar
ford390gashog
It's the remote bass **** for an aftermarket amp.
Old Oct 23, 2019 | 01:19 PM
OldChief's Avatar
OldChief
Thumbs up
Thanks gashog, that makes sense now. Pulled it out and it had a RJ11 connector (telephone line) that traced back to the rear where an aftermarket amp probably sat. Also found a 2 AWG wire running from the engine bay to the rear also disconnected at both ends. This was most likely the power line. Keeping the disconnected dash **** in so as not to have a hole in the dash. Case solved. Thanks for the help.
Old Oct 23, 2019 | 08:59 PM
Spaznaut's Avatar
Spaznaut
So do you have a factory head unit or an aftermarket unit? Would be curious if they spliced into the wiring for the input signal. Wonder if you have any other wires running to the back like rca cables.
Old Oct 23, 2019 | 10:12 PM
OldChief's Avatar
OldChief
A factory head unit. There were 3 wires/cables coming from the back with a separate grounding strap screwed into the floor panel. One wire was a line for power running up to the engine compartment, the 2nd was like a RJ11 telephone type wire going to the **** on my dash, and third was probably an RCA cable (no connectors) and runs up behind the radio unit. Looks like a professional job whoever installed the amp/wiring, but whoever took it out just cut all the cables in the back in order to grab the amp, most likely in the salvage yard.
Right now, the audio/sync/map unit works great and I'm kind of hesitant of digging in behind there and finding a rats nest. But my curiosity will eventually win out and I'll dig in there.
Old Nov 9, 2019 | 01:39 PM
Theboneskes's Avatar
Theboneskes
Isn't that **** for quitting the wife down? The more you turn it counter clockwise the more she shuts up! If only we were so lucky.... Don't tell mine I said that!
Old Nov 10, 2019 | 10:20 AM
OldChief's Avatar
OldChief
Dang! We wish I would have known that before disconnecting it!
Brandon Bloomquist
6.7L Power Stroke Diesel
Mar 24, 2013 03:27 PM
boxer.fan
Jun 27, 2009 04:56 AM
less
Jun 16, 2008 11:39 PM
HYDAFL
2004 - 2008 F150
33
Mar 14, 2007 05:37 PM
bpboothb
Sep 5, 2004 07:51 PM
