2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Upgrade/mod Suggestions
Old Nov 13, 2019 | 12:18 PM
clintusaf's Avatar
clintusaf
Talking Upgrade/mod Suggestions
Hey guys,
So I got my bone stock 2007 Navigator L a few days ago and so far, I’m loving it. Moving out of a 2002 F350 7.3.
anyway, I’m looking for suggestions on what to mod or upgrade. My goal is to keep it mostly stock but do a few things to improve the fuel economy and reliability.
1. Tuner/programmer - something simple to improve fuel mileage
2. Filter - stick with stock or upgrade?
3. Anything that needs to be addressed that is known to cause issues that would effect reliability?
All input appreciated
Old Nov 13, 2019 | 03:07 PM
clintusaf's Avatar
clintusaf
Just ordered an SCT X4 from 5 Star. Spoke with them over the phone and they were very helpful in answering all my questions (believe me I had plenty lol). Seems like really good people.
Old Nov 13, 2019 | 03:58 PM
mapitts66's Avatar
mapitts66
Yea, Mike Butler runs a 1st class operation. The one thing that I would add is that I personally stick with the OEM air intake. Flows plenty enough air for you and get a WIX air filter. Not sure you will get fuel mileage never tuned for that. I run an 87 octane daily tow on my wife's 2013. Got rid of the DBW feel and improved trans shifting. I run a very similar set up on my 2011 6.2 F250 with no complaints at all.
Old Nov 14, 2019 | 07:14 AM
clintusaf's Avatar
clintusaf
Alright I will probably just get a WIX like you suggested. Thanks.
Old Nov 14, 2019 | 07:18 AM
clintusaf's Avatar
clintusaf
So after scouring the forums, here is my initial list of planned mods/fixes are:
1. Programmer - purchased SCT custom tuned by 5 star
2. Replace Spark Plugs - looking into where I can find TSBs and which spark plugs to replace the old ones with. Also going to order extraction tool - Lisle 65600 part # and get some carb cleaner to spray them down good before removing
On Edit, I found the TSB - http://grufmanbil.se/webshop/mektips/tsb08-07-06.pdf
However, it doesn't mention a part number for the new plugs. Not a big deal since I'm assuming the replacements should just the standard 1-piece plugs, but could be wrong. Can anyone confirm?
3. Replace air filter - stock WIX replacement
4. Replace Heater Hose - Dorman 626-540
5. Swap to good Synthetic - is there a specific brand that is a favorite here? I know for my F350 7.3L, almost everyone seemed to use Rotella T6 Synthetic.
Let me know what you guys think
Old Nov 14, 2019 | 11:51 AM
gwcloud's Avatar
gwcloud
I would use the Motorcraft stock spark plugs - even though they are 2 piece.
I change plugs around 50,000 miles. The old plugs are still good but they can get stuck if left in too long.
The threads are not the problem, it is below them that collects carbon in the hole surrounding the lower part of the plug.
What works for me is: Change them with the engine cold. Break them loose about 1/8 of a turn and shoot some carburetor cleaner down the hole. Wait a little while. Next start turning them back and forth until they get loose. This will break up and dissolve the carbon.
Note: Nothing will penetrate past the spark plug seat until they are loosened a little bit.
Richard (2007 Navigator)
Old Nov 15, 2019 | 08:08 AM
clintusaf's Avatar
clintusaf
I thought I read somewhere that ford came out with a 1 piece to replace the two-piece ones with?
Old Nov 15, 2019 | 10:53 AM
gwcloud's Avatar
gwcloud
As far as I know Ford has revised the Motorcraft plugs but they are still 2 piece. Champion is the only one piece plug replacement that I have ever read about. The Champion plugs do not last as long as the Motorcraft ones do.
I have changed spark plugs twice and none of them broke. I was really worried the first time and was prepared to buy the Lisle kit if needed.
My Navigator gets 18-20 mpg driving at 70 mph while driving from So Cal to Seattle, Wa. That's a 2,500 round trip summer or winter. I think Navigators are great road cars. I don't check the mileage around town but I know it isn't very good.
If I could drive 50-60 mph on level ground the mpg would be 22-24 mpg. Not possible to drive like that in California because either it's too slow or too fast for traffic flow.
My odometer is at 97,500 now. I use 5w-30 Mobile 1 Annual engine oil and a Mobile 1 extended oil filter.
I haven't looked to modify the tune so I can't give any information on that.
Richard
Old Nov 16, 2019 | 07:08 AM
mapitts66's Avatar
mapitts66
OP, what is the mileage on your Navigator now?
Old Nov 18, 2019 | 10:15 AM
clintusaf's Avatar
clintusaf
I’m getting about 16 mpg with a good mix of city and highway
Old Nov 18, 2019 | 03:39 PM
mapitts66's Avatar
mapitts66
I am sorry, how many miles on the Navigator? You may want to pull the The throttle body and give it a good cleaning as well as clean the mass air flow sensor. 16 MPG ain't bad at all.
Old Nov 18, 2019 | 03:42 PM
clintusaf's Avatar
clintusaf
it’s got 83k miles on it. Ok anyone know where a step by step instruction of how to pull the throttle body is?
Old Nov 18, 2019 | 06:50 PM
mapitts66's Avatar
mapitts66
Pull your air intake up. unbolt the 4 bolts that hold it down or in, unplug the harness, clean with throttle body cleaner and a bottle brush, put it back together. Literally that simple. YouTube may have a video on an F150, yours will be very similar. Here you go. Nothing to it!
Satch
Aug 11, 2020 09:42 AM
Torren61
6.4L Power Stroke Diesel
May 10, 2011 05:56 PM
doubleman
Dec 10, 2008 05:50 PM
cdnite
May 27, 2008 06:01 PM
caseydudem
Apr 5, 2007 02:40 AM
