roller pushrod length???
Old Oct 14, 2004 | 06:41 PM
nate5812's Avatar
nate5812
Would using roller cam, roller lifters, and roller rockers call for a different or custom pushrod length?
Old Oct 14, 2004 | 06:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Yes, you will need to measure the length when the engine is assembled and order the proper parts.
Old Oct 14, 2004 | 07:37 PM
danlee's Avatar
danlee
You can order a pushrod length checker from summit or jegs. It is simply an adjustable pushrod. You install it and set the length to get the proper valve to rocker location. Then you remove it measure it and order the proper length pushrods.
Mine are 8.8". The stock 351M/400 pushrods are 9.5".
Old Oct 15, 2004 | 09:44 AM
beartracks's Avatar
beartracks
In my case I used all Crane parts and the push rods they sent were fine. You still need to verify the geometry on the engine.
IHguy
18
Nov 24, 2017 09:11 PM
Toplait
May 17, 2015 02:29 PM
FossenRacing
Oct 2, 2014 01:29 PM
Annihilator
Sep 18, 2004 07:22 AM
Ringo Fonebone
Jun 10, 2004 07:17 PM
