P0272
Old Oct 20, 2019 | 11:14 AM
Brandon l smith's Avatar
Brandon l smith
P0272
I’ve replaced #4 injector with new from ford injector and I’m still getting the same code p0272 if I plug injector in it white smokes really bad if I unplug it smoke goes away has a bad miss I’m at a loss with this truck where should I go from here
Old Oct 20, 2019 | 12:55 PM
Brandon l smith
Passes bubble test
Old Oct 20, 2019 | 07:12 PM
87crewdually's Avatar
87crewdually
Low/no compression, stuck valve, bent pushrod, broken rocker could cause an issue. When it is running, pull the oil cap off. Does it have alot of blow by?
When you crank it with just the starter trigger wire near the fire wall to the battery, does it crank evenly?
Old Oct 21, 2019 | 04:29 AM
Yahiko's Avatar
Yahiko
I would also think swapping two injectors to see if the problem stays or follows the injector.
Old Oct 27, 2019 | 03:28 PM
Brandon l smith
so I have cranked by trigger wire and it doesn’t crank evenly has a dead spot
Old Oct 27, 2019 | 07:48 PM
Yahiko's Avatar
Yahiko
Hydrolocked maybe?
Pull the glow plugs and stand clear of the holes when you try to crank it over.
The reason to stand clear is any liquid in the cylinders will come out under
very high pressure and can damage eyes or even skin.
Brandon l smith
Oct 27, 2019 03:25 PM
dirt_biker
Oct 18, 2017 02:26 PM
1993idi
Apr 7, 2015 10:26 AM
Rxracer27
17
Jan 5, 2014 04:59 PM
tobacco farmer
Apr 21, 2010 04:34 PM
