1 wire alternator
Old Oct 19, 2019 | 02:41 PM
DDB1973's Avatar
DDB1973
1 wire alternator
Installed a 1 wire alternator. Anyone know which wires I can now get rid of . To try and clean up engine bay?
Old Oct 19, 2019 | 10:21 PM
84espy's Avatar
84espy
Check this thread and you will see what wires can be removed along with the external regulator. I also add that a new battery with the dual post set-up works real well with the one wire alt. More landing points at the battery cleans up the starter solenoid, too.
https://www.ford-trucks.com/forums/9...g-upgrade.html
Old Oct 20, 2019 | 03:42 AM
1TonBasecamp's Avatar
1TonBasecamp
And are you 100% certain it's a true 1-wire alt and not just an internally regulated alternator that is often called "1-wire" instead?
Sorry if you knew that already and are sure, but more and more of them are being used and a lot of people still don't know the difference.
Which model did you get? A converted Ford unit, or a GM swap?
Paul
51chris
Electrical Systems/Wiring
May 20, 2011 10:47 AM
todd jo
Dec 7, 2007 08:10 AM
Ron Kelley
Aug 22, 2003 08:05 PM
inliner
Feb 25, 2003 02:12 AM
beartracks
Apr 8, 2002 08:59 PM
