motor mount bracket hole spacing
Old Oct 18, 2019 | 03:02 PM
ddan's Avatar
ddan
Is the hole spacing the same for a 4.9 as for a 3.0 V6? I'm referring to the three holes on the passenger side of the block that the motor mount bracket bolts to. I want to use the readily available Bronco, Econoline, etc. bracket in place of the discontinued V6 bracket. The V6 bracket is inverted so it cups water, road salt, coolant, etc., then rots and breaks! (Aerostar) It might be inverted for clearance reasons, but I'm still curious if the hole spacing is the same or close.
Old Oct 25, 2019 | 09:22 AM
AbandonedBronco's Avatar
AbandonedBronco
Hey ddan, I moved your thread over the 300 I6 forum, since it isn't specifically Bronco related. You'll have a better chance of getting an answer over here.
KelVarnson
Oct 26, 2012 10:37 PM
jmooremtb
Jan 23, 2004 07:38 PM
pod4
Sep 16, 2002 11:13 AM
