mushroomed steering shaft
Old Oct 16, 2019 | 03:13 PM
crabdad's Avatar
crabdad
With my impatience to get my column back together; and not waiting for help. I mushroomed the head of my steering shaft along with a broken piece of wood and 2 bruised knuckles. what would the fix be? File until close diameter and rethread? if so , any one know what the those are? I have to learn how to be more patient.
Old Oct 16, 2019 | 03:35 PM
unimogger's Avatar
unimogger
I'd carefully use a flap when on a grinder to taper the end of the shaft, (cutting off the mushroomed area) and use a sharp thread file to clean up the first two turns of thread. I have split thread dies in half, so they can be back threaded over damaged threads, but it is a delicate task and not everyone has the tools to do it. PM me if you want details though..
Old Oct 16, 2019 | 03:45 PM
Mark8man's Avatar
Mark8man
Maybe post a pic if you can so we get a better idea of the extent of damage. I have used a Dremel with a thin cutoff wheel to restore fine threads. Helps to have one of those magnifier headsets
Old Oct 21, 2019 | 04:18 AM
crabdad's Avatar
crabdad
Got it. Had the mechanic at work look at it, He ran his thread chaser on it and it was good as new in less than 5 minutes. Spindle thread was 5/8-18 if anyone needs to know. Thanks for your replies.
82GT
May 24, 2010 12:13 PM
BuickBrian
Nov 11, 2008 12:03 PM
buckeyebronco
1978 - 1996 Big Bronco
May 16, 2006 05:21 PM
eduardo
Oct 11, 2005 12:05 AM
