PCM diagnostic
Old Oct 16, 2019 | 10:31 AM
Rl69's Avatar
Rl69
PCM diagnostic
I have a 1995 f350
ever sence I had the truck it has had hard shifting. I have to feather the throtel to keep from jarring the truck . Some days it's not as bad as others
about a moth ago every now and then I started runing higher rpm then normal . Last night the truck started just dieing??? After a minet or two it would crank back up,and run a few miles or a few feet. When it wouldn't start I didn't have the wate to start light or the lighter . Whenever it would the light would come back on and the lighter would work.
After doing sing some reading it seams the probabll problum is the pcm
so so my question is is there a way to tell I feel to bad and the way it's doing seams like a bad connection proublem can it be cleaned
im no mechanic but I can turn a wrench ask my anything y'all need to to help solve I'll do my best to answer
Old Oct 16, 2019 | 05:07 PM
427 fordman's Avatar
427 fordman
Electrical is not my strong suit, but saying that I know the lighter and pcm are on the same fuse. Id be looking at the fuse box/wiring connection first. If you don't find anything diesel technology of Chattanooga tests and repairs pcms.
Old Oct 20, 2019 | 10:52 AM
Rl69's Avatar
Rl69
Ugggg I hate electrical ! I got home yesterday around two fired up the truck it ran for around two hr.... ( number one and two relay very warm ? )
Today I started it up drove around the yard drove nrxt door drove around his yard killed it... stared it back up... It's been runing for the last five hr ???
Old Oct 20, 2019 | 10:54 AM
Rl69's Avatar
Rl69
I've pulled pushed shook every wire fuse relay on the truck ???
BigDaddyG
Sep 26, 2013 02:44 PM
DHamSTER
Sep 10, 2013 09:51 AM
bublitz3
Jul 8, 2012 06:39 AM
blue1ton
May 29, 2012 04:31 PM
crispena
21
Nov 4, 2011 01:33 PM
